What are torque specs for head bolts and main bearings? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-23-2012, 11:09 PM
MONAVIERONJON MONAVIERONJON is offline
MONAVIERONJON is starting off with a positive reputation.
About to snug the new head on and could really use the info on how much the OEM torque is and also on the crank/ piston bolts. Would be good to know tolerances as Im about to plasti gage the main bearings.......... thankx!!!!!
Old 09-23-2012, 11:47 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
Here ya go. Cylinder heads.
Old 09-24-2012, 11:05 AM
excellent, thanks for the help, ROnjon
Old 09-25-2012, 01:16 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Pete, If you were doing head studs, is that the order you would put them in at torque step one and do the step two and three?
Old 09-25-2012, 01:42 AM
pjwoolw's Avatar
IIRC the ARP instructions have the same illustrations and specs torque wise. But if I were to do the one at a time swap I would follow the same pattern. That really doesn't answer your question Glenn. I can't recall what they did on the rig I witnessed having the head studs installed in that manner. Clay would know for sure.
Old 09-25-2012, 01:49 AM
BlueMule's Avatar
BlueMule BlueMule is offline
BlueMule has a good reputation on FTE.BlueMule has a good reputation on FTE.
Glenn
If you're just replacing bolts with studs without removing the heads you risk breaking the seal between the head/gasket/block if you start @ 65 and work your way up to 105. When I did mine I replaced one bolt at a time using the sequence as in step 2 and torqued it to 105 and then used the sequence in step 3 to bring them up to 125.
Old 09-25-2012, 08:50 AM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
Start at factory spec, 105 ft lbs and then move up doing it one for one.
Old 09-25-2012, 09:58 AM
Sounds good, thanks!
Head gasket #01truckfan 1987 - 1996 F150 & Larger F-Series Trucks 2 09-11-2015 06:03 PM
1964 F-100 262 Torque Specs? greenmachine319 1961 - 1966 F-100 & Larger F-Series Trucks 2 01-23-2011 12:47 AM
Main & rod bolts after bearings, TTY - does anyone reuse or is new required JACKA$$ 1999 - 2003 7.3L Power Stroke Diesel 8 01-29-2010 10:19 AM
torque specs 83f100ss Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 01-24-2004 11:54 PM
crankshaft thrust bearing problem Rico82nd Performance & General Engine Building 13 10-28-2003 09:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
