Anyone here ever done a 5.9 cummins swap? (03-06)
looking for someone i can talk to that has done a cummins swap on there 7.3l, my motor is well past its way out, and if im gonna start dumping the dead presidents this is seriously being considered. I know its doable, i just need to find out what you used, the issues you ran into, and a complete (or as close as i can get) to a parts list, so i can have everything ready to rock and roll once my truck gets back to my shop in ohio.
edit--more so specifically, wiring, and drive shaft lengths since i know the 4r100 gets moved a bit (even with the cummins to ford adapter and flex plate it still gets moved about 1/2 an inch if i recall correctly), and whether or not you used the cummins fan or bought the adapter to use the ford fan.
edit #2-- depending on what i find out ill keep you guys posted on here (might be a cummins conversion build, or a complete 7.3 teardown and rebuild with some special goodies)
im not much help, but Destroked - THE Cummins Conversion Company : Home Page and i know theres another website out there for it
its a start
1995 cummins 12 valve w/ fordcummins adapter plate super duty
Depending on if still available, and your wanting to pursue it, if you want to pull the trigger, i can make sure it GETS shipped.
Heres one for ya
https://www.ford-trucks.com/forums/1...ion-build.html
Heres another one
https://www.ford-trucks.com/forums/7...on-update.html
Heres another one
Shmit90051
31
05-22-2019 09:11 PM
