Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 09-23-2012, 01:10 PM
willowbilly3 willowbilly3 is offline
Garage is empty, add now
willowbilly3 is gaining momentum as a positive member of FTE.
The gears are always churning
So, I have had this idea about the independant front 4x4 like the Aerostar has. And as we are walking around the junkyard I find an Expedition that has been rolled. It runs good and I can get it cheap. The track width is a little wide, 72 inches outside so that is a little of a problem Unless I can redrill the hubs for some earlier wheels with a more favorable offset.
Now I am usually the first one to discourage frame swaps but I still can't help thinking how a fridge body would fit that chassis. It has torsion bars so you can get it pretty low, I like a pickup I can work out of and not have to crawl up in the bed after things.
  #2 (permalink)
Old 09-23-2012, 07:27 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Well, if you stop thinking and dreaming they might as well throw dirt in your face right now! That does sound a little wide. I assume you have considered the crown vic approach?
  #3 (permalink)
Old 09-23-2012, 07:53 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Redrill the hubs. Tires are so innaccurate and out of round, it doesn't make that much difference if you are 2 thousands off or whatever. 4 wd, independent suspension.... sounds good. BUTTTTT the crown vic thing if you are of that ilk... lower, etc I think from reading here that it is a match made in heaven. ... Disc brakes (12" I think) bolt on... 34" frame width. Now if they only made a 4wd crown vic............
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
