Quick Tire check before purchase
09-23-2012, 05:24 AM
Hi Guys,
Im just doing a quick check before i pull the plug on a purchase.
Looking at the Goodyear Wrangler Duratrac 325/65R18
Will these tires work on a stock 2012 F-350 ??
09-23-2012, 07:56 AM
I wouldn't go that wide on the factory wheels, but that's just my opinion.
It will "work" but the tire is likely to wear funny being the center is sucked in so much on a skinny wheel.
09-23-2012, 09:02 AM
Im currently running 275/70/18 right now.
09-23-2012, 09:04 AM
295 ish is the widest tire I'd put on the stock wheels.
09-23-2012, 09:43 AM
So stock rims are only 8" wide?
09-23-2012, 09:50 AM
I believe they are 8" wide.
09-23-2012, 09:56 AM
How can i check without removing the tire?
09-23-2012, 09:59 AM
on
Check the driver side door jamb sticker
I got a 250 and the stock rims are 18 x 8
Nice tires by the way
09-23-2012, 10:06 AM
Ok so ive got 18x8. So you dont want to be wider than that. But is 0.3" really too much wider?
09-23-2012, 10:16 AM
09-23-2012, 10:18 AM
And that kida is why you dont do math after a 12hour night shift. Hangs head in shame
09-23-2012, 12:52 PM
It depends on how much air you run in the 325s, if you run the at 65 or higher then they should wear Ok, just my .02...........I always run my LT tires hard like 75 to 85 PSI
09-23-2012, 12:53 PM
I have 295 nitto terras on these XLT 18 inch rims and that's as large a tire as I'll go.
Makes the truck look great though over the 275 conti's.
09-23-2012, 01:37 PM
on
I just purchased those exact tires(same size).....but they are on aftermarket rims. If you don't have at least a leveling kit of some sort on the truck I would not go that big.
09-23-2012, 02:12 PM
295 tires look really good and perform very well. I would not go wider if you ask me.
