Edge CS or Gryphon CS ???
Hi there,
French owner of a rare ( in France) F150 4,6 liter '97, I tow an Airstream for holidays or American events . Sensible F150 as the engine burns LPG and gas, I want to get permanently a diagnostic of what happens during a trip and, why not, some HP or torque ....
I 've seen that Edge CS what a solution so I 've just discovered Gryphon CS that seems more valuable than Edge ( may be more power with the same look ??? ) .
I need your advices .
Thank you by advance
A Gryphon is a custom tuned Edge. Custom tunes are better (in my opinion) than the stock ones because it allows the tunes to work for your truck specifically and allows for better performance. Sites like PowerHungryPerformance.com doe custom tunes for the Edge CS. Custom tunes are not that much more expensive and if you have the money I would highly suggest it, however, if you do not want to go that route, even the stock tunes on the Edge CS are an improvement over what the truck already has.
FORD996
2004 - 2008 F150
04-21-2009 08:18 PM
