Help with power steering pump hose?
In the picture here, am I supposed to shove the hose on all the way through the elbow to the base of the pump, or just up until the bend? How to I make that bend, as some elbow grease hasn't done it yet. If my hose was the yellow area in the pic, it only pushes on to that point. Am I supposed to round the bend on that one?
1978 and later plastic reservoir P/S pump: P/S pressure hose has a straight tube with an o-ring at the pump end. Connects to the pump using a qwik connect fitting, other end threads onto gear.
P/S return hose has fitting on gear end, rubber hose on pump end, clamps onto P/S pump elbow.
ndBrody
10-01-2018 08:48 PM
ubermich
04-23-2018 11:51 AM
dusterbd13
12-10-2014 01:28 PM
ManfredVonRichtofen
12-18-2011 08:02 AM
