2007 F550 loss of power
I have a 2007 f550 6.0 diesel. has about 20,000 miles on new engine. I filled up with diesel got to a quarter tank the truck started cutting out and missing loss of power.
Starts good no water in the oil, no smoke. I bought some water out and it ran good. A few days later I got diesel at another store I filled up at a half tank and the truck ran worse. just missing and cutting out. at low rpm's truck does good.
Has any one had this problem before.
Thanks
Thanks
Just curious. Have you changed your fuel filters regularly? If so, what do they look like when they're removed? Do you see foreign deposits on the primary filter? The reason I ask is because an F-550 is obviously a cab and chassis type truck and therefore uses an after axle metal tank that seems to have issues with the inner lining of the tank delaminating, which can cause a fuel inlet restriction, and in turn the concern you describe.
. I changed the fuel filters when I put the motor in I don't remember what they looked like. I drove the truck about 2000 miles. It is a flatbed. When I run all the diesel out I will change the filters . Or should I do it now. Do they make a after market fuel tank
Thanks for your reply
I found out what was wrong with my truck
I changed my fuel filters and it was full of water and sluge. I drained the fuel tank. Flushed the fuel system. Added fresh fuel and injector cleaner.
Seems to be Runing fine. But im hopeing it dident hurt my injectors. There was no drain plug. Something I need invest in.
Thank you all for your replys and I hope this helps someone else.
Yes there is a Plug to drain the Water they ALL HAVE ONE
Sounds like you have the OEM ALLEN Head Plug for the water separater Drain its on the Fuel pump on the frame
Judging by what you found the HFCM (Fuel Pump on the Frame) needs to be cleaned out as well
I will see if I can find a Pic
The Water separater on the Pump is more than Likely full of Junk Too
Its between the 2 Arrows that Point down towards the Wires
the Bigger Round Circle thing towards the Bottom of the FLAT Middle Plate
Take that Flat Cover Plate Off its probably Full of JUNK IN IT
Here is the Link to the thread with cleanout procedure Bismic Posted
https://www.ford-trucks.com/forums/9...ml#post8346209
Here^^^^^^^^^^^^
bike_guy123
10-10-2013 09:06 PM
Fat Diesel
15
09-13-2010 06:25 AM
2danglong
06-01-2009 03:02 PM
