Need Help. P0012, Im stumped
Old 08-31-2012, 07:28 PM
nlaao03's Avatar
nlaao03
nlaao03 is offline
I have a 2005 f-150 5.4 3V. I bought it used with 136xxx miles knowing it had a problem. Code p0345. When it warmed up and idled around parking lots ect... it would somtimes make a clunk and start idling really bad(making that diesel sound.) I enjoy learning about motors so I thought I would try to tackle this. I have receipts from the PO showing a local mechanic doing the timing kit, sparkplugs. On the drivers side only he replaced the exhaust manifold gasket, Lash adjusters, VCT solenoid, and cam sensor. He also said he had the oil pressure checked and it was good.
Now the things I have done: Replaced both cam phasers, The other vct solenoid and cam sensor. When I took the passenger side valve cover off I noticed on the #4 cylinder the very last rocker and cam lobe was tore up. Cam lobe was wearing into the roller rocker. Why it was apart I changed the camshaft, 12 lash adjusters, the one bad roller rocker. I inspected the other and they appeared good. After putting it all back together it runs the same. the only difference is it is throwing a p0012 code now. I went and had the oil pressure checked myself and it was at steady 30 psi at hot idle. I marked the cam phasers, camshaft, caps on the camshaft, and put the rockers back in there origanal locations. Now Im stupped and don't know what to do next. The only thing I can think of is taking the front cover off and make sure the timing is right. Any help or ideas will be greatly appreciated.
Old 09-01-2012, 09:27 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Did you use the wedge tool to hold the chain in place? If not then its possible the chain could have moved on the crank, which will require the timing cover to be removed and the cams re-timed. I explain how to time the cams in another thread, search for "timimg a 5.4" (I know its misspelled, thats what the thread is called)
Old 09-01-2012, 11:19 PM
nlaao03's Avatar
nlaao03
nlaao03 is offline
Yes I used the wedge tool. I think a timing check would be my next step. I read through that post a couple of times now. I think I'm ready to try it. I was reading through my chiltons and it looks like a pain to remove the timing cover. Do you really need special pullers for the crank and power steering pump. Is there a how to on that somewhere here. I have searched and came up empty. Thanks for all the help.
Old 09-02-2012, 09:02 PM
70f100longbed
You need a harmonic balancer puller for the crank pulley and I take off the PS pump with the pulley and lines still on. Those pullies can be a PITA sometimes. A 10mm reversible gearwrench makes getting the pump off a lot easier. There is one bolt that is right behind the pressure line fitting that is hard to get to without the gearwrench.
Old 09-03-2012, 04:24 PM
nlaao03's Avatar
nlaao03
nlaao03 is offline
Thanks for tips. I will probably get started in a week or so. I hope this will be it.
Old 09-21-2012, 09:02 PM
nlaao03's Avatar
nlaao03
nlaao03 is offline
I finally got the timing cover off to inspect and retime the motor. One of the tensioners had a bad seal. After looking more closely to them I also noticed I had two Left tensioners instead of a left and right. I got everything back together and the truck went about 3 days before the CEL came back on. When and got it read and still the same p0012. Motor still shakes and knocks when idling around after it is warmed up. Does it every time I drive it. I got referred to a ford mechanic and explained to them my problem and they are telling me to drop oil pan and check the pick-up screen and check the crank bearings for wear. I guess that will be my next step later down the road.
Im open to any and all other suggestions.
One other thing I noticed that looked replaced was the drivers side VCT body looked replaced. I guessing this engine has been around and no one has got it figured out yet.
1994 F150 2x4
1997 - 2003 F150
05-30-2017 01:13 PM
Brad Brown
Modular V8 (4.6L, 5.4L)
01-04-2017 11:55 AM
TX92F150
04-28-2015 10:50 PM
sosotwo
2004 - 2008 F150
08-04-2014 12:49 PM
sleep_deprived129
03-13-2009 11:31 PM
Quick Reply: Need Help. P0012, Im stumped
