i have a 1996 f250 7.3, im trying to figure out what the junction is that bolts to the fuel filter housing. the fuel pressure regulator is a part of this junction as well as the water in fuel sensor. can anyone help?
Welcome to the forum.
IF I understand your question, those bolts (there are two) are precisely to join the FPR to the fluel filter housing, but if I missunderstood, this is a BUMP for you. But the water in fuel sensor is not part of that, its the fuel restriction sensor IIRC.
its the junction that those two bolts are holding to the housing, mine is cracked and leaking. it has 2 rubber lines that connect to it and two solid lines to it. plus that sensor. i am trying to figure out what that whole junction that all those things connect to is?
