Fan Hub Oil Level - Ford Truck Enthusiasts Forums
Fan Hub Oil Level
Old 09-21-2012, 03:28 PM
fixnair's Avatar
fixnair fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
Fan Hub Oil Level
How much oil should be in the fan hub? Also, should there be a static leak if the level is too high?
I bought a rebuilt hub for my '52 flathead V8 and I don,t think it should be leaking regardless of the level, am I right?
Thanks for any input. When I call C&G I want to know what I'm talking about.
Old 09-22-2012, 04:05 PM
aussiecowboy aussiecowboy is offline
aussiecowboy is gaining momentum as a positive member of FTE.aussiecowboy is gaining momentum as a positive member of FTE.
I'm surprised no one has answered this yet. I want to know also, and what oil weight?
Old 09-22-2012, 04:15 PM
Old 09-22-2012, 05:46 PM
5 Star's Avatar
5 Star 5 Star is offline
5 Star is starting off with a positive reputation.
Turn the fan pulley with the screw on top. Remove the screw, fill with engine oil let set for a few minutes, now turn the pulley with the hole downwards let the excess oil drip out.
Now turn the pulley right side up replace screw and you done lubricating it.
Old 09-22-2012, 07:41 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
Exactly what the shop manual says.
Fan hub lube Tomc750 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 02-18-2015 10:55 AM
auto hubs wont stay locked cattlerancher 1999 to 2016 Super Duty 5 11-27-2014 09:43 PM
F250 4x4 Hub Vacuum Leak daculpepp 1999 to 2016 Super Duty 7 12-28-2013 10:57 PM
How much is too much (oil through the turbo)? SSSimon 1999 - 2003 7.3L Power Stroke Diesel 6 08-29-2013 09:22 AM
explorer front differential seal brucememp Explorer, Sport Trac, Mountaineer & Aviator 11 11-05-2004 11:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
