which gear ratio do i have?
Old 09-20-2012, 10:05 PM
Bluethunder3320's Avatar
Bluethunder3320
Bluethunder3320 is offline
im planning to do a SAS (dana 44) on my f150
im not sure what gearing it has, where could i find this out?
1989 F-150 custom 4x4 5 speed 300 i6.
Old 09-20-2012, 10:16 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
Look at the door jamb sticker. Here is a decoder to figure out a lot of info contained on said sticker: Vin Decoder - FSB Forums
Old 09-20-2012, 11:00 PM
96f15013ddie's Avatar
96f15013ddie
96f15013ddie is offline
Super Helpful link Ive had this f150 since april and still didnt know the gear ratio
Thanks
Old 09-21-2012, 08:16 AM
rla2005's Avatar
rla2005
rla2005 is offline
Anytime!
Old 09-21-2012, 08:22 PM
Bluethunder3320
got the codes and they dont match the decoder. it says "M9" in the box for axle. what does this mean?
Old 09-21-2012, 08:28 PM
danr1's Avatar
danr1
danr1 is offline
Are you sure that's not an "H" as in H9?
Bad angle on the picture but looks like a H to me.
Old 09-21-2012, 08:37 PM
framerboy's Avatar
framerboy
framerboy is offline
The picture is a bit tough to see. Is the ''m'' really an ''h''. If so H9 usually means a 3.55 ratio with limited slip in this year truck.
Old 09-21-2012, 08:40 PM
Bluethunder3320
i believe its an H. my bad. thank you!
jroehl's Avatar
jroehl
jroehl is offline
I agree on the 'H'. The 'H' means that it's limited slip (if the first of the two digits is a letter, it's limited slip), and if I recall, the '9' means that it's a 3.55 ratio.
Jason
Old 09-23-2012, 01:17 PM
96f15013ddie
Why would they put 2.73's on my truck wouldnt 3.55s be better power/mileage balance?
Old 09-23-2012, 02:44 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
For pure highway driving(unloaded) you have the optimal gears
Old 09-23-2012, 02:48 PM
Conanski's Avatar
Conanski
Conanski is offline
Only in areas that are flat in all directions however.
wildcard221
02-15-2017 06:23 PM
WarWagon
04-12-2007 10:54 PM
bks90F150
02-20-2006 12:11 PM
troy payne
18
06-29-2004 10:54 PM
ole_blue
Offroad & 4x4
03-14-2002 06:09 PM
Quick Reply: which gear ratio do i have?
