1 Piece Halo Angel Eye Headlight For F-150
I'm new here and just post the news I heard this afternoon that there is 1 piece Halo Angel Eye Headlight will be available soon for 97-02 expedition , since it is interchangeable with 97-03 F-150 , so I post it here as well , maybe someone will have more info for me , thanx .
I just got these today they look awesome Just a little confused with the wiring through. I had the regular projector lights with the seperate clear corners before that had the leds in them (only 2 wires for led) No problem with those just spliced the day time lights and I was good to go. These new one piece with the Angel Eyes HALo have a bunch more wires for the LED part of it. Three RED two WHITE and one BLACK. So now I gotta figure out where I spice em and what wire is what.
I got em figured out I got the brightest PIAA bulbs in there They don't look much different then the $4 I got off ebay before. I want to Put HID in there but some sites say the housing can't handle them. My Buddy has a Denali withangel eye projector and he's running 8500k HID for a couple months now with no problems
Don/John,
Maybe you could help me.
I installed a projector headlight 1 piece for my 98 F150. Also in this headlight are 5 LED at the bottom. The turn signal, low/high beam are bolt in. My problem is the 5 LED, I am not sure where to connect the wires. It had two sets of wires. The first set are 4 wires (2 red/2 white), the second set had 2 wires (red/black). Any help would be greatly appreciated.
Thanks.
Thanks.
Last edited by Torque1st; 09-05-2005 at 07:00 PM. Reason: remove email address completely
...Welcome GoldenBruno, to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
I just connected mine to the existing turn signals by splicing the wire and soldering it. Also make sure the wires you have are your turn signal wires and not the ones for the actual halo or angel eyes. I just connected the 2 wires to the 12v battery and found out which wire was for what. I hope this helps
Cheers,
Cheers,
customfab
05-07-2015 03:55 PM
Eskipper20
05-05-2014 11:10 PM
tmkemp79
02-13-2012 11:48 PM
ynm22
1997-2006 Expedition & Navigator
17
08-04-2004 11:54 AM
