351w running rich? - Ford Truck Enthusiasts Forums
351w running rich?
Old 09-20-2012, 06:15 PM
Shwan_89HD's Avatar
Shwan_89HD Shwan_89HD is offline
Shwan_89HD is starting off with a positive reputation.
351w running rich?
After getting an oil change done, my mechanic said i think your running rich because he smelled a gas smell from the exhaust. I was in a rush and didnt have much time to talk more about it. What could be the problem here?
Old 09-20-2012, 07:28 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Perhaps your mechanic is trying to pad his wallet? Before getting too wrapped up from their comments why don't you check for codes. The PCM will tell you if it thinks the engine is running rich or lean or ???
Old 09-20-2012, 07:38 PM
Shwan_89HD's Avatar
Quote:
I do have a check engine light on.... And i dont think hes trying to scam me cause i have smelled that gassy smell from the exhaust for quite a bit
Old 09-20-2012, 07:42 PM
rla2005's Avatar
Then you should check for codes to see what the PCM is trying to tell you. Ignoring it is not going to make it go away.
Old 09-20-2012, 07:54 PM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Pull vacuum line off regulator and see if it's leaking. That's where I always start first.
Old 09-21-2012, 01:22 AM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
Better yet, check and see if your fuel tank is leaking. If you have dual tanks, the top of the rear one usually rots out from everything getting tossed on it from the tires. You'd definitely smell fuel that way. But check the codes, the computer will know what's up better than a mechanic who didn't check them.
Old 09-21-2012, 10:54 AM
Shwan_89HD's Avatar
Quote:
Ya i went to autozone to see if they can read the code for me, but my computer is too old for them to read, they only read i believe vehicles 96 and newer, so im gonna have to take it to a mechanic for them to read it. Could it be a faulty O2 sensor? im noticing also a decrease in performance and especially mpg
Old 09-21-2012, 11:50 AM
GNR22's Avatar
That's odd. Usually parts stores carry obd1 and 2 readers since you can make money off of someone that needs a part. Go online and order an obd1 reader. They're very cheap
Old 09-21-2012, 12:14 PM
UNTAMND's Avatar
Look in this forum. You'll find a list of codes and how to check them on your EEC4 computer (obd1) with just a paper clip and a functional check engine light.
Old 09-21-2012, 01:00 PM
D-ford D-ford is offline
D-ford is starting off with a positive reputation.
Yes i agree with untamnd i have a great code reader and it and its great just count the beeps/ blinks and look them up in the book it comes with and done.
Old 09-21-2012, 06:09 PM
rla2005's Avatar
Old 09-24-2012, 12:02 AM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
Give this guy some rep points! Great post as always. I have to spread myself around before I give you any more points lol
Old 09-24-2012, 08:55 AM
rla2005's Avatar
You are too kind.....
Nothing special about my post, just pointing out the obvious and most overlooked item you should do when working on these trucks.
emiss light on dragford 1987 - 1996 F150 & Larger F-Series Trucks 15 01-10-2017 08:32 PM
Holley 2300 running too rich with #74 .0800 jets Papas66 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 04-19-2014 12:32 AM
93 f150 5.0 running rich 1990-f250 1987 - 1996 F150 & Larger F-Series Trucks 3 03-12-2014 11:16 PM
Running rich ldfry001 1968-2013 Full Size Vans 1 09-14-2013 10:51 AM
Rich smell? kameronth 1978 - 1996 Big Bronco 1 11-27-2003 01:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
