Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-20-2012, 01:24 AM
irwnn irwnn is offline
Garage is empty, add now
irwnn is starting off with a positive reputation.
1965 Econoline Intake and Carb Options
Quote:
Originally Posted by irwnn View Post
Click the image to open in full size.
I've got a '65 Econo on which someone used JB Weld to "repair" the carburetor float mount. It now runs like crap because the JB Weld is letting go and the float is erratic.
I purchased a reman carb for a 170 from Rock Auto to get me by while I do further research. If anyone has any info indicating that the 170 carb will not work on the 240 intake, let me know so I can cancel the order.
On to the fun: I haven't been able to find any info on the fitment of a Clifford or Offy intake to the Econoline. Anybody know if there's enough room without modifying the dog house?
Thanks,
p
  #2 (permalink)
Old 09-20-2012, 01:35 AM
Econoline leaky transmission
I've got a '65 Econo...
  #3 (permalink)
Old 10-08-2012, 05:29 PM
Well, the 170 carb doesn't fit. The mounting studs are larger on the 240 manifold and the throttle linkage is all wrong.
Next up a '67 240 carb. It's a better fit, but the hole where the spark control valve goes is different. It's apparent that the '67 didn't use a spark control valve (or at least not the same style as the '65), but something needs to plug that hole. Can anybody here tell me what goes there, if there's a way around it, or where I can get it?
Thanks,
P
  #4 (permalink)
Old 10-09-2012, 03:07 PM
This turning into a real PITA.
I've been all over the internet and all over Charlotte. I can't find a single image of an Autolite 1101 with the style port that is on the one I got from Rock Auto. Everything I've found has shown the same style spark control valve that's on the bad carb I have.
P
  #5 (permalink)
Old 10-10-2012, 05:35 AM
OGB OGB is offline
OGB is starting off with a positive reputation.
Years ago (over 40) I took the Carb/manifold gasket to napa and had them match a Holley Economizer Carb to it but I did have to open up the mounting hole one size because the offset was slightly different. This was on a 300 six application which should be the same. I know it was a Holley and 90% sure it was a Economizer. If that doesn't work how about auto wrecking yards. Or give Clifford a call and ask them http://www.cliffordperformance.net/h...s/contact.html
  #6 (permalink)
Old 10-12-2012, 01:57 PM
Thanks OGB. I think, since I have the '67 carb in hand, I will try just plugging of the holes in that odd port and see how the van runs.
BTW: If my computer had not caught on fire I would use that to post here and include pictures. Since it did catch on fire, I'm using my phone and cannot include pictures.
  #7 (permalink)
Old 10-12-2012, 05:55 PM
OGB OGB is offline
sounds like lately if you didn't have bad luck you wouldn't have any luck at all.
  #8 (permalink)
Old 10-12-2012, 08:02 PM
You wouldn't believe it if I told you. ;-)
  #9 (permalink)
Old 10-20-2012, 06:49 PM
j-md's Avatar
j-md j-md is offline
j-md is starting off with a positive reputation.
Offy and Clifford intakes will not work in our dog houses. Edelbrock will but they are rare and expensive when found.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
