Transmission leak
Transmission leak
My transmission decided tO blow it's nose down the road today, transmission leak... It's at the rear between the xfer case and transmission. Xfer case is pretty dry on top but from the transmission back is nice and oiled up again. Can't tell if it's the seal or that shifter motor deal at the bottom. Thoughts? Thanks in advance for any help! Just learning how to use one of these here I telephones so I don't know how to post pictures off of it but will tomorrow. Thanks buds.
Muekster, I am 99.9% sure thats not the issue, the top sides of both the transmission and transfer case were both dry.
Bad this is im pretty sure this happened while the transmission was cold too.. right when i left work and got on the road i heard what sounded like air comming out of a compressor hose (whoosh), so if that was it then it blew out pretty good when it happpened and by the time i got home then 30 minutes later when i found it there wasnt a leak, so its onl leaking while engaged, not while just sitting there.
on
Ford cant find the problem, says the seal is fine. Cant find any other leaks. Could the transmission breather hose be plugged and forced fluid into the transfer case??? They want to keep the truck over night and see if anything starts to leak. Said they drove it about 25 miles and nothing is wrong... any other ideas???
OldGrayFord
06-30-2013 11:25 PM
04Terminator
08-10-2012 03:59 PM
Big-old-460
03-09-2011 06:11 PM
limptera13
04-29-2010 04:02 AM
