best bet for no start: bad IDM or PCM?
About to start throwing $ at the truck again to get it to start. Just to recall, tach bouncing, bats charged, turns over and over with nothing out the pipe. Pulled and cleaned the IPR. Have checked all fuses and unplugged fuel bowl heater. Unplugged my chip. Thinking either bad PCM or IDM. Looking at remaned ones on ebay. What is my best bet bad PCM or IDM?
1) Fuel
2) High Pressure Oil
3) Signal to the injectors
Make sure the fuel bowl is full.
Make sure the HPOil reservoir is full.
Use a scanner or mechanical gauge to monitor HPOil pressure and make sure it'll climb to 500 psi or more when cranking.
As long as the HPOil pressure is there then the ICP sensor should read the pressure and tell the computer to fire the injectors.
If you crank for a while then start to hear clicking, the computer/idm are trying to fire but there's an issue with the HPOil system somewhere.
You can try unhooking the glow plugs and spray very small amounts of starting fluid into the turbo while cranking. This will spin the engine over much faster and if it starts you'll know the computers are good and it's something mechanical.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
A split second isn't long enough. If it's not staying on for a couple of seconds at least, then that's your problem. Start by removing the chip (key out of ignition first). See if that changes anything. Leave it out while you troubleshoot.
Next unplug the fuel bowl heater to see if that makes a difference. Then leave the key on and have someone watch the dash while you grab and wiggle any wiring harness you can see under the hood. If you can get the WTS light to flash by wiggling a harness, look for a short there.
rwdfan
02-21-2012 09:53 PM
1997F-350
22
06-04-2010 08:07 PM
