Heat Issue
Heat Issue
I need help diagnosing a heat problem. I have a 2001 F150 XL. 4.2L Manual controls. The a/c blows nice and cold, but when you put the heat on its not really hot, blows warm air. I changed the blend door actuator,it got a little warmer. Now that winter is around the corner need to figure it out and fix it. The thermostat, water pump, and coolant flushed before I bought it. Could it be the blend door itself, or is there another actuator I'm missing.
Your heater core is blocked by sediment over the years there is a powder concentrate you mix in gallon of water pour directly into heater hoses after you disconnect them from wall.this could work to unblock let it soak, blow out with compressed air, however only temp fix. U will need to change heater core, there is a really good video step by step on ytube on how to change it. Took me about 6 hrs to do it.
Thanks, I'll give that a try. Could it be something else? The truck was one of my jobs service vechile I bought from them when they bought new ones. They had the heater core flushed out and it never changed? I was told possible blend door, since they did have issues with cracking causing hem not to fully close when switched from cold to warm.
The AC is cold but did you try and move the heat setting to warm with the AC on? If so did the AC get warmer when you changed the heat setting? If it did get warmer then it might be a clogged core but if the AC stayed real cold when you put the heat control to warm it is most likely the blend door.
When you changed the blend door actuator did you check with a mirror and/or bent tool to see if the blend door itself turns or the shafts' hole was broken (plastic pieces fallen out when removing actuator? Check the Treater video and they supply blend doors if your up to the job.
Ford F150 '97-'04 - '97 - '04 - F150 - Ford
