How common is lower radiator hose collapsing?
on
I found this:
The CHT sensor has two wires to it, Gray/Red and Yellow/Light Green.... its located near the t-stat housing ... see pic below
Cut from my Ford Service Manual:
Cylinder Head Temperature (CHT) Sensor
Removal and Installation
1. Remove the upper intake manifold.
2. Remove the cylinder head temperature (CHT) sensor.
A. Disconnect the electrical connector.
B. Remove the CHT sensor.
3. To install, reverse the removal procedure.
on
I found this:
You need to change/check that sensor or you can just keep having the same issues you're having now. Up to you.
If the sensor doesn't fix it, there were a few people a few years back where the PCM was the faulty bit.
If you have a datalogger, have it log the CHT and coolant sensor, and see if the CHT goes wacky in comparison.
At some point, not sure when, I think the CHT was inferred from the coolant temp, or vice-versa, but that might have only been the 5.4...
f15olandscape
03-19-2013 11:15 PM
