2004 6.0 Automatic sometimes will not go into gear - Ford Truck Enthusiasts Forums
Old 09-19-2012, 12:11 PM
1fixitman's Avatar
1fixitman 1fixitman is offline
1fixitman has a very good reputation on FTE.1fixitman has a very good reputation on FTE.1fixitman has a very good reputation on FTE.
This truck is a friend of mine's. 2004 6.0 diesel 4wd Automatic Stock 225,000 miles on the truck. Sometimes the truck will not come out of park when putting into Drive or Reverse. If he steps on and off the brake a few times it eventually goes into gear. It does not happen all the time....just sometimes. I don't know if it is a linkage problem in the column, electrical Brake Pedal Position switch or maybe something to do with a brake Pressure Sensor. I am open to ideas.
Dwayne
Old 09-19-2012, 01:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
My SWAG is the brake light switch. That triggers the solenoid that releases the shift handle.
Old 09-19-2012, 05:31 PM
daddykitty's Avatar
daddykitty daddykitty is offline
daddykitty is gaining momentum as a positive member of FTE.daddykitty is gaining momentum as a positive member of FTE.
Quote:
what does SWAG stand for...mine is doing the same thing
Old 09-19-2012, 05:42 PM
BPofMD's Avatar
BPofMD BPofMD is online now
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Don't worry...that wild-AZZ guess is pretty dang good!
Old 09-19-2012, 06:56 PM
1fixitman's Avatar
Electrical switch in the cab on or near the brake pedal master cylinder operating rod or the pressure switch in the engine bay on or near the master cylinder? Thank you.
Old 09-19-2012, 07:09 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
Mark is referring to the switch connected to the actual brake pedal itself inside the cab, the one that activates the exterior brake lights when the pedal is depressed, as well as provides an input to the PCM.
Old 09-19-2012, 07:50 PM
1fixitman's Avatar
Thank you for the confirmation. I will advise James as to what to check. I did tell him that for over 200k he has been doing very well with his truck. Maybe he will just go ahead and purchase a new switch. Any ideas on part number for this item from ford. I will see if I can find it on Tousley ford parts website.
Dwayne
Old 09-19-2012, 08:49 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
TORQSHIFT TRANSMISSION WONT COME OUT OF PARK BRAKE PEDDAL SWITCH ONTO THE SILINOID
http://www.ford-trucks.com/forums/11...ixed-pics.html
Old 09-19-2012, 09:09 PM
BPofMD's Avatar
Posting Legend
Do the brake lights go on and off with brake pedal?
Old 09-19-2012, 09:20 PM
Quote:
Silly Wild A** Guess
Quote:
Yes, I meant the switch on the top of the brake pedal.
Old 09-19-2012, 09:29 PM
daddykitty's Avatar
Is there a magic decoder thread so i know what all the abbreviations you guys use translates to?
Old 09-19-2012, 09:49 PM
BLADE35's Avatar
ACRONYMS FORD
http://www.ford-trucks.com/forums/821641-acronyms.html
Thats most of them
The Home Made ones your on your own LOL (SWAG)
Old 09-19-2012, 10:22 PM
daddykitty's Avatar
yeah i am having trouble with the home made ones not the ford ones...ttyl
Old 09-20-2012, 10:47 PM
1fixitman's Avatar
I am pretty sure that this is the part. $57 plus shipping. Pretty good.
2004 Ford F-250 SUPER DUTY Parts - Tousley Ford Parts Depot
Old 05-09-2013, 07:22 PM
Enduroman's Avatar
Enduroman Enduroman is offline
Enduroman is starting off with a positive reputation.
I'm having similar trouble with my shifter being stuck in Park. When it started happening a few months ago I opened up the Brake Pedal Switch and cleaned it up with a wire brush and contact cleaner. There was some corrosion present. Looked like new going back in. It seemed to help for a while, but now its doing it again and the contacts in the switch are still squeaky clean. I bought a new Brake Pedal Switch but once I install it, I can't return it. My shifter is pretty sloppy - presumably from the previous owner cranking on it trying to get it in gear. Can anyone tell me if the solenoid in the column is prone to failing, when its been cranked on? Any way to check it? If not, I'll fire in this new switch and hope that does it. Thanks
2003 6.0 CC 4x4
2004 6.0 falls on its face. busters1195 6.0L Power Stroke Diesel 16 12-10-2016 01:12 AM
Sometime no reverse Poorboy04 6.0L Power Stroke Diesel 15 08-27-2013 12:23 AM
transmission problem please help Bthutch04 6.0L Power Stroke Diesel 35 01-06-2013 06:31 PM
Fuel economy for 2004 6.0L markwiebe 6.0L Power Stroke Diesel 12 12-01-2009 10:21 PM
2004 F-350 P2285 code, ICP hdhummer 6.0L Power Stroke Diesel 2 07-12-2009 07:16 PM
Tags
777
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
