2004 6.0 Automatic sometimes will not go into gear
Old 09-19-2012, 11:11 AM
1fixitman's Avatar
1fixitman
1fixitman is offline
This truck is a friend of mine's. 2004 6.0 diesel 4wd Automatic Stock 225,000 miles on the truck. Sometimes the truck will not come out of park when putting into Drive or Reverse. If he steps on and off the brake a few times it eventually goes into gear. It does not happen all the time....just sometimes. I don't know if it is a linkage problem in the column, electrical Brake Pedal Position switch or maybe something to do with a brake Pressure Sensor. I am open to ideas.
Dwayne
Old 09-19-2012, 12:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
My SWAG is the brake light switch. That triggers the solenoid that releases the shift handle.
Old 09-19-2012, 04:31 PM
daddykitty's Avatar
daddykitty
daddykitty is offline
what does SWAG stand for...mine is doing the same thing
Old 09-19-2012, 04:42 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,098 Likes on 998 Posts
Don't worry...that wild-AZZ guess is pretty dang good!
Old 09-19-2012, 05:56 PM
1fixitman's Avatar
1fixitman
Electrical switch in the cab on or near the brake pedal master cylinder operating rod or the pressure switch in the engine bay on or near the master cylinder? Thank you.
Old 09-19-2012, 06:09 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Mark is referring to the switch connected to the actual brake pedal itself inside the cab, the one that activates the exterior brake lights when the pedal is depressed, as well as provides an input to the PCM.
Old 09-19-2012, 06:50 PM
1fixitman's Avatar
1fixitman
Thank you for the confirmation. I will advise James as to what to check. I did tell him that for over 200k he has been doing very well with his truck. Maybe he will just go ahead and purchase a new switch. Any ideas on part number for this item from ford. I will see if I can find it on Tousley ford parts website.
Dwayne
Old 09-19-2012, 07:49 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
TORQSHIFT TRANSMISSION WONT COME OUT OF PARK BRAKE PEDDAL SWITCH ONTO THE SILINOID
https://www.ford-trucks.com/forums/1...ixed-pics.html
Old 09-19-2012, 08:09 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Do the brake lights go on and off with brake pedal?
Old 09-19-2012, 08:20 PM
Mark Kovalsky
Silly Wild A** Guess
Yes, I meant the switch on the top of the brake pedal.
Old 09-19-2012, 08:29 PM
daddykitty's Avatar
daddykitty
Is there a magic decoder thread so i know what all the abbreviations you guys use translates to?
Old 09-19-2012, 08:49 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
ACRONYMS FORD
https://www.ford-trucks.com/forums/821641-acronyms.html
Thats most of them
The Home Made ones your on your own LOL (SWAG)
Old 09-19-2012, 09:22 PM
daddykitty's Avatar
daddykitty
yeah i am having trouble with the home made ones not the ford ones...ttyl
Old 09-20-2012, 09:47 PM
1fixitman's Avatar
1fixitman
I am pretty sure that this is the part. $57 plus shipping. Pretty good.
2004 Ford F-250 SUPER DUTY Parts - Tousley Ford Parts Depot
Old 05-09-2013, 06:22 PM
Enduroman's Avatar
Enduroman
Enduroman is offline
I'm having similar trouble with my shifter being stuck in Park. When it started happening a few months ago I opened up the Brake Pedal Switch and cleaned it up with a wire brush and contact cleaner. There was some corrosion present. Looked like new going back in. It seemed to help for a while, but now its doing it again and the contacts in the switch are still squeaky clean. I bought a new Brake Pedal Switch but once I install it, I can't return it. My shifter is pretty sloppy - presumably from the previous owner cranking on it trying to get it in gear. Can anyone tell me if the solenoid in the column is prone to failing, when its been cranked on? Any way to check it? If not, I'll fire in this new switch and hope that does it. Thanks
2003 6.0 CC 4x4
Quick Reply: 2004 6.0 Automatic sometimes will not go into gear
