Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 09-19-2012, 09:50 AM
crtrck48 crtrck48 is offline
Garage is empty, add now
crtrck48 is starting off with a positive reputation.
Body Removal
I am doing a Lincoln Make 8 IRS swap on my 62. I could do it with the body on but it would suck. What is the best way to remove the body with jack stands and a jack? I need to get the frame out from under it bacuse i dont think i can get the body high enough. Thanks for the help, Matt
  #2 (permalink)
Old 09-19-2012, 07:49 PM
jacks61ford's Avatar
jacks61ford jacks61ford is offline
jacks61ford is starting off with a positive reputation.
what I did when I took my frame out was jack it up as high as you can get it put the frame on jack stands unbolt the body and wheels and don't forget the e brake cables and steering box the unbolt the body from the frame jack it back up off the stands and put stands under the door area with a block of wood tand I used the splash pan on the back I used blocks of wood then lower chassis take the wheels off I left the drums on with a couple lug nuts to stop them from falling off and it rolled right out no biggie .
  #3 (permalink)
Old 09-20-2012, 11:21 PM
garbz2's Avatar
garbz2 garbz2 is offline
1963 Ford F-100
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
I Used a similar method to roll the frame out from under the chassis. I used two floor jacks to roll the chassis.
Here are some shots of the front supports i made to be able to roll the body around with a single floor jack at the rear.
Click the image to open in full size.
Garbz.
__________________
98 528I BMW
64 F100 "Christine II" 390 NP435 6" lifted 2 wheel drive
63 F100 Uni Custom under construction 4" off the pavement and built to drive.
69 M250 Crew Hiboy 472 C6 Ranger, getting a full rebuild.
  #4 (permalink)
Old 09-21-2012, 12:27 AM
37 Ford guy's Avatar
37 Ford guy 37 Ford guy is online now
1966 Ford F-100
37 Ford guy is gaining momentum as a positive member of FTE.37 Ford guy is gaining momentum as a positive member of FTE.
Garbz.
Hey Garbz, you have any more pics of those front supports? How are they attached?
thanks!
Randy
  #5 (permalink)
Old 09-22-2012, 05:09 PM
garbz2's Avatar
1963 Ford F-100
Simple 3/8 all thread with washers and nuts through the upper fender bolt hole and lower bolt hole. 3x1 tubing welded in to a tee and with spacers to the cowl and lower mount.
The wheels are from ? i had them laying around. I used solid stock for the axles with a cotter and washer to hold it on.
Here is from the front.
These are all i have salvaged off an old drive.
Garbz
__________________
98 528I BMW
  #6 (permalink)
Old 09-22-2012, 08:48 PM
1966 Ford F-100
Garbz
Thanks Garbz! That helps. I wasn't sure where you were bolting it on but now I do. What would make that one step more versatile is to build it out of an old trailer hitch jack that would allow you to raise it up and down - maybe even high enough to roll the chassis out and back in when ready to put the body back on....just sorta thinking out loud.....
  #7 (permalink)
Old 10-18-2012, 08:40 AM
okiewelder okiewelder is offline
okiewelder is starting off with a positive reputation.
irs
Did you ever get it installed?
Did you use the kit or just make the mounts yourself?
I have been interested in the swap myself.
Thanks,
Steven
  #8 (permalink)
Old 10-18-2012, 02:13 PM
I got the body off by drilling out the body bolts from the top, removing the rear end and springs, jacking up the truck and sitting the body on 5 jackstands. I ripped 2 2x4s down to 2.5 inches, i put those in a groove under the body that goes from the front of the cab to the front of the bed. I put jackstands on those boards at the front of the cab and the rear of the cab on bother sides. I put the 5 jackstand at the back of the body where it drops down just below the liscense plate.
I did get the rear in tacked in and put the frame back under the body to make sure it looks right with the wheels on it. It looks good so i will pull the frame back out and burn it all in and paint the rest of the frame. I did buy the kit. Not to take anything from Dave but the pieces in the kiat are simply but it saved me time figuring it out and making the brackets myself. YOu also buy the support when you buy the kit. I called Dave a couple times and he is very helpful. Matt
  #9 (permalink)
Old 10-19-2012, 06:43 AM
Do you have any pictures?
Im in oklahoma where are you located?
I c'd the back of my frame and put the rear ontop of the springs.
I dont think they had the kit out when I did mine.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
