Any brake surgeons out there?
One thing I discovered (by accident) at work was that if you over-tighten a brake line, it can block off flow. I tried forever to get fluid out of the rear wheel cylinders, nothin. Another tech loosened the line to the flex hose just a little, got all the fluid in the world. Verify you've got fluid at all 4 wheels, then I'd say its a booster issue
Have you tried bleeding the system with the truck running?
I've done this in the past for vehicles I had problems with getting all the air out of the system. I know that isn't your problem, but you can definitely tell if the booster is working or not. It should blast fluid out way harder than it does without the truck running.
I believe all f250's had dual piston calipers in our year range, don't know that for a fact though. I do know there is a difference in the master cylinders depending on whether or not you have cruise control, at least for some years, but I think its just a pressure cut off sensor.
I also don't know if you could bolt an f150 booster in there as I have never tried. I would guess not, but even if it was possible I would think it would give some power assistance and it doesn't sound like you are getting any.
