239 flatty fired up !!!
Good news this morning from the engine shop .The 239 flatty for the stock truck is running . About time over 3K & 2 yrs later . Will make a trip up there early wed. morning . He said it has 2 minor problems .
1. LH H2O pump is leaking . One was rebuilt . I don't remember which .Any suggestions where to get a quality rebuilt pump for a reasonable price . Would any one on the site have a good LH pump ?
2. Also stated the carb was trashed .I cleaned it all up & installed a rebuild kit . I guess I am better at wood working than carb rebuilding . Again any one have a source for a quality rebuild at a reasonable price ?
This engine is nearing a $$ pit . Need some help . Thanks , Denny
NOS pumps are likely still available. I'll see if I can find you one.
You can also try EGGE Machine in California. I'd trust their work. EGGE Machine Company - Parts and Services for Nostalgic Motors
Denny - Charlie Price at Vintage Speed is right up the road from you at Vero Beach. I got a nice rebuilt carb from him that works well and looks great too.
What is the carb doing wrong? These are simple carbs. You can fix it. Make sure all passages are open. Shoot carb cleaner thru them. Pay careful attention to the power valve (correct gasket so it does't leak). Set float level to 1 7/16" w/o the gasket. Ues a fuel filter inline before the fuel pump. Check needle and seat for debris that causes the needle to stick. All parts are available from Vintage Speed as mentioned above. Don't give up. Good luck...jack
Speedway water pumps are good.
Visited the engine shop early ( 9 am ) wed. morning . I think I found the reason it took 2 yrs. for the build . It wasn't lack of funds on my part but those guys start tipping the cool frosties a little early in the am. for me . They were already on the Mick lights when I arrived there . I told them if they had to hit it that early they might as well drink something that has some kick to it . . One can drink nearly a six pack of that brand & barely get a minor buzz !!
The engine ran very well . Has been decades sionce I've heard a flatty run .Seems the carb butterflies were not opening freely . Had rapid thoughts of brining it home , install , and related components but still owe them some $$.
Have a LH H2O pump on the way .
If another carb rebuild by Firstrider doesn't work another FTE member offered to rebuild it .Will keep you posted .
If VS rebuilds it, upon getting it home, take it apart and blow out all passages really well, and make sure all internal parts are matching. I haven't had dealings with VS, but one minute of research on the HAMB will net you many folks that have had mismatched parts. Even more concerning, after dissembling the carb, being able to pour glass beads out of it.
Am I knocking VS, no, certainly not. Many people have had good luck with him. But, the topic arises on the HAMB on many occasions, and too many people have had the above problems to chalk it up to coincidence.
http://www.jalopyjournal.com/forum/s...=charlie+price
http://www.jalopyjournal.com/forum/s...e+price&page=2
http://www.jalopyjournal.com/forum/s...=vintage+speed
http://www.jalopyjournal.com/forum/s...e+speed&page=3
78fourby4f250
06-14-2012 04:55 PM
luthoro
09-22-2011 10:43 PM
79 f-150 guy
16
04-18-2011 08:09 PM
peboiteau
15
10-17-2009 10:58 AM
