You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I live in Medford and I'm working on doing a 4x4 conversion on my 2wd F-100. I have everything but new (j-yard) radius arms, rear driveline and I need to find a new outer shell for my NP-208 transfer case. The t-case is married to an NP-435 and comes with front diff, 3rd member, front driveline, both IFS axles, 3-4" lift (front/rear), Warn Hubs, dual shock setup, add a leaf, axle shafts and several misc parts. I'm only doing the conversion for an as needed scenario, I'm not looking to go wheeling or anything. I got the 300 4.9L L6 and have done a lot of work to it. After I get all the parts I need for the conversion, what kind of things should I do to ensure everything is going to work how it should or what I should do before/during/after the whole conversion?
That is a big project, I know on the older trucks, that the frames are so different between a 2wd and a 4wd, that makes it very hard to convert one. I have a 80 Bronco with the IFS, I have not looked at a 2wd to see what is different about them. Post pictures of your project to see how it is going.
__________________
Allen D
1966 F-100 4x4 with 390 GT engine
1990 Areostar 2wd XLT ext
1980 Bronco with 460
1976 F250 4X4 Custom with 429
Oregon Chapter Member: To join the Oregon Chapter, click HERE
I'll post pictures as soon as I can so you can see the progress I have made. It's going to take me a little to get it done because the truck is my daily driver.
Sense it bolts to the tail of the C6, which should be the same, SHOULD be. Check to see if it transfer cases are the same type.
__________________
Allen D
You can have the tail shaft changed to fit a transfer case
__________________
Allen D
