97 f-350 convereter
Try running it without the Superchips. See if it acts any different.
If the O/D cancel button was flashing there would be a code we could pull but I am thinking that it is shifting like it should. If it is not flashing, then I don't think the trans is hurt, I just think you have some other issue making drivability suffer a little.
Maybe unhook the MAP sensor's electrical connector (near the blower motor under the hood and has a hose going to the intake manifold) and see if it shifts any different that way. If the engine is down on power it will make the transmission shift funny.
I will try unhooking map sensor and see what that does I have replaced the turbo,glow plugs (had to remove the head to get one out that was broke) cpm sensor,throtle pedal sensor,all fuel lines around filter,and fuel filter,all 3 idler pulleys and I still have a gralwing noise when it lug any at all just anytime your not givin it fuel. Have not figured that out yet either..lol
DeathRangerofDeath
12-21-2016 01:43 PM
white 01
04-02-2005 12:08 PM
