CPS help please.....Pulling my hair out!!
I don't know if my truck info will post with this so here is my truck:
1997 F350 DRW, 7.3L PSD, bone stock.
Now my problem: In the last six months I have burned through six cps's (all of them were the grey ones from Advance Auto). I did some research over the weekend and decided to try the part # css1103 from Napa(also a grey one). It lasted overnight and failed the next morning. The other six on lasted a month or so as well.
The symptoms are all of a sudden, it will run like its only firing on about 4 cylinders. It takes having the foot pedal to the floor just to keep it from dying. It throws a SEL at this point until the cps is replaced. I have had the codes checked and there are none about the cps, but I don't know if they were using the correct diagnostic tool either.
I have done some research on this forum about this and related problems and have found that others recommend using the black cps. I checked with the nearest stealership and they want about 20 bucks more than what this part goes for and its a grey one as well. I also found out that the grey cps's were supposed to have been farmed out for production to china.
My questions are first, is there anything else in the system that could be making my truck eat cps's? I have checked the harness leading to it and there aren't any bare spots. (the loom is still intact even) Can't find any broke fuses either.
Second, is the black cps available anywhere other than ordering it from a website on the internet and will it fix this problem?
Six or seven months ago, when this problem first started, the cps that failed was a black one. Don't know if this makes a difference but I figured I would include it anyway.
Please feel free to chime in..........I am going crazy here trying to just keep this truck on the road!
Thanks for any help.
I think the most logical place to start is to get a good CPS from the dealership and see how it runs with that in there. Until then, we are kind of guessing.
In fact we are kind of guessing anyway without knowing what the codes are that are setting the CEL. If it were mine I would:
1- order a new CPS from Riffraff Diesel HERE
2- check the valve cover connectors to see if you have any burned pins. I would probably also ohm out the injectors and harnesses through the valve covers to see if you have a problem under the valve cover. You're going to be ohming between the center pin of each 5 pin connector and the two pins beside the center pin. You're looking for around 3.2 ohms on each injector. The reason I suggest this is that the IDM can shut down a whole bank of cylinders if it senses that there is an issue with an injector or wiring harness. My theory is that the CPS isn't actually your issue, but replacing it is masking the problem.
I still suggest getting a new (Motorcraft) CPS just because it is only a matter of time until the cheap CPS IS actually the problem and replacing it is a cheap way to eliminate that as a possibility.
I did in fact replace the IDM 2 years ago. As for the replacement CPS, I am looking for the best angle on this. The one at RiffRaff looks like a winner. As son as I can shuffle some funds, I will probably order that one. Any clue how long they usually take to ship items?
Also, I will need to check and see if I have an ohm meter. I have a voltage tester(digital) but I will have to check and see what all it will test.
Thanks for the reply and I am still checking this so chime in if anyone else has suggestions.
Riffraff usually ships the same day you place the order. Nice price too.
If you have a digital meter, it should test resistance (ohms). It is usually the setting with the Greek symbol Omega on it. Looks like this:
The pins in the 5 pin connector on the valve cover are as follows: GP-INJ-COM-INJ-GP.
GP=Glow Plug
INJ= Injector
COM= Common
You want to test between the common and each injector in that connector, then unplug the next one and test that set of injectors. Four connections total. This saves you a little time in pulling the valve covers off to visually inspect the under valve cover wiring harnesses (UVCWH's) and injectors separately. If you get some screwy readings, then you have to go in there anyway, but at least then you know where to start.
GP=Glow Plug
INJ= Injector
COM= Common
Thanks guys for all the input! I will see if I have an International dealer close by. Seems like I have seen one recently here. When I get things in a forward motion, I will repost here with an update. I also have a Suburban that is in need of plug wires and it sucks being almost broke until payday (8 days from now blah).
Well guys, here is the update: My Dad ordered a CPS from RiffRaff Diesel and I got it on Friday. Put it in and bingo, popped right off! No blue smoke, no hesitation, just the good old cackle and growl.
I got 2 driving tests yesterday after putting it in and went to the store to grab dinner. On the way out of the parking lot, a woman wasn't even looking and blew the stop sign she was supposed to stop for. It was raining and I couldn't get the 9k pound beast out of her way so I cut the wheel hard to the left, locked up the brakes and tried anyway! Passenger side dually hit her jeep in the frontend and ripped the axle loose and pulled the driveshaft out of the transmission! I get so sick of idiot drivers that just get in and drive and don't pay attention! She got a ticket on the scene and I am going to bring up the fact that her tinting on her side windows was so dark that you couldn't even see a figure through the window.
Anyway, thanks for the advice about the CPS problem. Also, RiffRaff doesn't sell the black CPS anymore, they are the dark blue ones. They said they quit making the black ones about 2 years ago.
Again, thanks guys!
Again, thanks guys!
Holy T-bone Batman, this was not how I suspected your CPS problem to be solved!!
6 sensors in 6 months, are there really that many bad ones or could something else be damaging them? I read that some sensor had to be shimmed but don't recall if they where making contact or just too close to be effective.
Good to hear!!
Store sensors
IMO purchasing one from the internet or parts store is a big gamble because it's just left over inventory from the past.
barkmulcher
23
09-02-2011 01:14 PM
Tailspin
03-03-2008 11:40 AM
glenn-rod
02-25-2008 01:16 PM
Mindstream
34
01-26-2007 07:32 PM
