Parking Brake light
Make sure parking brake lever is returning all the way up. pull release and then grab lever and lift. Might be a weak spring or dirt/corrosion on the cable. Most drivers do not use the brake and this may cause problems to develop. Its important to use it as-designed. Stop the truck with the service brake; holding the service brake, put trans in Park; holding the service brake, set the parking brake; turn off engine and release service brake. To drive, start engine; hold service brake; release parking brake; put trans in gear; release service brake. This prevents wear/damage to the parking pawl in the trans and exercises the parking brake. Eventually a brake that is used will need adjustment.
I've got the same problem with the light. Mine is because of the magnetic float in the master cylinder. Something went wrong with it. its fairly common in the cruisers my garage services at work. I just run it with the light on. Looks bad but I haven't been ambitious enough to fix the issue
Shadowe
01-14-2005 06:10 PM
saltzy
1997-2006 Expedition & Navigator
10-06-2004 12:30 PM
