Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 09-17-2012, 03:40 PM
wag53 wag53 is offline
1993 Ford F-150
wag53 is starting off with a positive reputation.
5.0 High Performance
OK, recently bought a 1993 F150 ext cab XLT with Mark III option and 5.0 High Performance engine. Does anybody know anything aout this option? The PO said it was rated at 210 HP. Can't seem to see anything different about the engine, looks just the same as my old 5.0 in a 1990.
  #2 (permalink)
Old 09-17-2012, 05:02 PM
GNR22's Avatar
GNR22 GNR22 is online now
1989 Ford F-250
My Garage
GNR22 is gaining momentum as a positive member of FTE.GNR22 is gaining momentum as a positive member of FTE.
As far as I know, the Mark III option didn't have any kind of engine modification, it was all show. A 5.0 HO does exist though. They put them in Mustangs. They're good motors in a car, or a lighter truck. I'm pretty sure the HO 5.0 motors said 302 HO on top of the motor, so it would be visual unless it's changed. I believe that the HO motors were like 220 horse and 300 ft/lbs of torque, something like that. But I'm pretty sure those 5.0 motors in trucks were rated for right around 200 horse, maybe a little more in that time period.
If I'm wrong, someone will correct me.
__________________
--Davey
-1989 F250 (RCLB) 4x4, 4speed NP435 tranny, SAS D44HD, 351w, 3.55 (L/S front and rear), F250/350 Hybrid Suspension, Pacesetter Shorty Headers, into 3" Summit Racing Street and Strip Mufflers, 235/85R16 Uniroyal Liberators.
-1994 Thunderbird LX, Moonlight Blue, 4.6L, Automatic, Bone Stock
-2012 Focus SE
  #3 (permalink)
Old 09-17-2012, 10:40 PM
impish impish is offline
Garage is empty, add now
impish is starting off with a positive reputation.
5.0L H-O eng. began useage in late 1980s w/ fuel injection, my 1989 had roller camshaft, but not roller rocker arms. This continued up till 1995. However, in 1993, Cobra was re-introduced, WITH roller camshaft AND roller rocker arms, as well as larger capacity fuel injectors.
Regular 5.0 H-O engines in Mustang had 19 lb/hr injectors, Cobra had 24 lb/hr, requiring DIFFERENT calibration of computer. 5.0 HO was rated nominally 225 HP, Cobra 245 HP. impish
  #4 (permalink)
Old 09-17-2012, 10:49 PM
Nathanl25's Avatar
Nathanl25 Nathanl25 is offline
Nathanl25 is starting off with a positive reputation.
The only difference that i knew of between the regular 5.0 and the H.O.'s, was that the H.O. had a different taller cam lobe and firing order. Allowing it to breath better and run smoother, while making more horsepower.
  #5 (permalink)
Old 09-17-2012, 11:28 PM
Quote:
5.0s in trucks did not come with roller cams. The firing order was also different, actually, the old, familiar Ford V-8 firing order from years back.
5.0 H-Os as used in Mustang (and maybe Lincoln), had a REVISED firing order, which Ford claimed RELIEVED some load on the FRONT MAIN BEARINGS. Thus, messing with interchanging camshafts causes plenty of confusion, due to the firing order difference, not to mentioon the fact that H-Os had STEEL gears on the distributor shafts, which would EAT the cast iron gear of the flat-tappet camshaftr, if used with an H-O distributor gear.
(watch the locations of those plug wires, guys!).
impish
  #6 (permalink)
Old 09-18-2012, 07:17 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
1980 Ford F-350
My Garage
Diesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to behold
Quote:
You were LIED to. The MarkIII conversion was cosmetic ONLY.
BUT an easy way to tell if you have a5.0 HO in your truck would to look at the plentum. If it goes over the passenger side valve cover it is NOT. If it goes over the drivers side vale cover it IS
__________________
96 F350 CCLB 460 5pd 4x4 /97 F250 CCSB Dually 7.3 5 spd 4x4
94F150 RCSB Lightning/86 F250 RCLB 6.9 4spd 4x4
80 F350 RCLB 429 C6 4x4/
04 Ranger SCSB
96 Bronco 347 5speed
  #7 (permalink)
Old 09-18-2012, 09:09 AM
lew52's Avatar
lew52 lew52 is online now
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
impish
....The 94 + truck 302s had roller cams , and some had mass air and sefi , the cams were just samaller than the HO cam , they have the same firing order as the HO and used the steel cam gear for the steel roller cam....
  #8 (permalink)
Old 09-18-2012, 09:24 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Actually some trucks were equipped with roller cams as early as '92 but it was the tiny Crown Vic cam with the old firing order, these trucks were the dumping ground for all kinds of leftover bits unfortunately.
As for the PO's question about his MK3, you would know if you had a HO.. the truck would really haul with the hammer down.
__________________
Paul (Conan) O'Brien
1990 5.0HO AOD XLT X-Cab F150 3.55LS, 1990 2.3L 5-sp Ranger 3.08, 2004 3.0L 5-sp X-cab Ranger Edge 4.10, 2004 2.5L 5-spd Subaru Legacy
1996 Kawasaki ZX11D, 2004 Honda 599, 2008 Kawasaki KLR650
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
