48? Ford F2 project - Ford Truck Enthusiasts Forums
48? Ford F2 project
Old 09-17-2012, 04:01 PM
maestro1024 maestro1024 is offline
maestro1024 is starting off with a positive reputation.
48? Ford F2 project
Hello,
I am being given a Ford F2 and I thought it was a 47 but the guys on the 47 and older site said it was at least a 48
What engines available in 47 F2 And where to start with one? - Ford Truck Enthusiasts Forums
Here are the pics.
Anyone tell me anything else about this truck and where I should start or any good advice
Old 09-17-2012, 04:34 PM
badger_hound's Avatar
badger_hound badger_hound is offline
badger_hound is gaining momentum as a positive member of FTE.
Welcome to the forum! Let me throw out a few guesses here...
front clip style = 1948-1950
grill with no ss trim or holes drilled = 1949-1950
cast instead of stamped f2 badge = 1949
Decoding your VIN will provide you with more specific info about your truck though.
And, there are plenty of more knowledgeable folks here that can give you more details than I can! BTW, where are you located?
Old 09-17-2012, 04:43 PM
It doesn't have a bed. Was it probably a wood bed that rotted or fenders that are were removed? Did they have both options?
Old 09-17-2012, 04:44 PM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
If its a six and not been changed, it will be a 226 with a side mount dist, if V8, 8ba or 8rt, dist, in front of the right side head. If orig V8, it will have a drain **** under each water pump. Have also been told that the first 8ba in the 48 trucks used head studs instead of bolts.
Old 09-17-2012, 04:56 PM
Quote:
It looks to me like you have the factory short running boards (rounded off past the doors), so your truck probably did not originally have an express bed (the fendered, boxed bed). But it is a pretty old truck, so the bed may have been removed and the running boards swapped out some time in the distant past.
Old 09-17-2012, 05:21 PM
52'F-3's Avatar
52'F-3 52'F-3 is offline
52'F-3 is gaining momentum as a positive member of FTE.
smaller back window is a 48 to 50 model
F600 Super Bronco build. Death Metal recommendations. Recipes. 78_f800crewcab4x4 1973 - 1979 F-100 & Larger F-Series Trucks 254 12-31-2016 10:42 PM
My truck thread aussie_f350 Australia Chapter 98 08-02-2016 02:21 AM
'02 Power Fold/Telescope Mirror Swap Eaglestroker 1999 - 2003 7.3L Power Stroke Diesel 25 09-08-2015 12:24 PM
Power Rear Slider Conversion Eaglestroker 1999 - 2003 7.3L Power Stroke Diesel 9 04-13-2015 11:55 AM
San Jose plant visit + pics (big) transam525 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 09-20-2014 07:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
