Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 09-16-2012, 08:53 PM
Snowbirds11b Snowbirds11b is offline
2012 Ford F-350
Snowbirds11b is starting off with a positive reputation.
Minor changes on 6.2L
Just take possession of my new f350 6.2L dually last week and found that they change the valves covers, the new ones are black in composite. Does everyones have 3 1/2 inch tail pipe, i dont talk about the chrome one?
  #2 (permalink)
Old 09-17-2012, 07:34 AM
Knothole's Avatar
Knothole Knothole is offline
2012 Ford F-250
Knothole is starting off with a positive reputation.
The tailpipe on my F250 is 3 1/2" OD.
__________________
<a href=http://i47.tinypic.com/rm3acn.jpg target=_blank>http://i47.tinypic.com/rm3acn.jpg</a>
2012, F250, Lariat, 6.2, FX4, 3.73
Before you Die....Take time to Live
  #3 (permalink)
Old 09-17-2012, 07:42 AM
2012 Ford F-350
Thanks Knothole
  #4 (permalink)
Old 09-17-2012, 09:01 AM
BMWBig6's Avatar
BMWBig6 BMWBig6 is offline
Garage is empty, add now
BMWBig6 is starting off with a positive reputation.
Yeah we've seen the black plastic valve covers on F150 6.2's too. Not sure why Ford switched though.
__________________
Ben
2011 Ford F-150 Lariat Limited (#3252 of 3700)
2009 Audi A4 2.0T S-Line Avant / 2008 Audi TT 2.0T S-Line Coupe
Retired: 2003 Ford SVT Lightning / 2001 Ford SVT Lightning / 1993 BMW 740iL / 1990 BMW 535iM / 1986 Porsche 944 Turbo / 1983 Porsche 944
  #5 (permalink)
Old 09-17-2012, 11:02 AM
2012 Ford F-350
Probably heat dissipation or modification in vapor management for the PCV valve, alot of time the only way to discover changes is when you ask for a specific part in the engine and they ask you the build date of the engine: before or after or the suffix change like AA to BB.
  #6 (permalink)
Old 09-18-2012, 11:19 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
Quote:
Congrats on the new SD! Pics...yeah...share some pics...
To be honest...I haven't noticed the valve covers on my 6.2L. Gosh...going to go take a look tomorrow.
Just interested...but what where they before???
biz
__________________
2012 FORD F250 SD CC 156" Lariat FX4 6.2L BOSS 4x4 4.30s
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s -- Traded
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #7 (permalink)
Old 09-19-2012, 10:00 AM
BMWBig6's Avatar
Quote:
This is what the valve covers looked like on the F-150 6.2's before.
Click the image to open in full size.
2011 F250 SB 6.2:
__________________
Ben
  #8 (permalink)
Old 09-19-2012, 07:14 PM
biz4two's Avatar
Arrow
So...were they cast aluminum?
biz
__________________
  #9 (permalink)
Old 09-19-2012, 08:59 PM
2012 Ford F-350
No,
Cast-iron engine block and four-bolt main bearing caps, with cross bolts, for durability
Aluminum cylinder heads, with two valves per cylinder and two spark plugs per cylinder
Cast-iron crankshaft, with dual-mode damper
Forged steel connecting rods
Cast-aluminum pistons, with cooling jets
Single overhead camshaft with variable valve timing and roller-rocker shaft valvetrain
***Magnesium cam covers for lighter weight***
Stamped-steel oil pan
Composite intake manifold
Stainless-steel fuel rail; port-fuel-injected; mechanical returnless fuel system
9.8:1 compression ratio
E85/flex fuel capable
Magnesium is a highly flammable metal, but while it is easy to ignite when powdered or shaved into thin strips, it is difficult to ignite in mass or bulk. Once ignited, it is difficult to extinguish, being able to burn in nitrogen (forming magnesium nitride), carbon dioxide (forming magnesium oxide and carbon) and water (forming magnesium oxide and hydrogen). This property was used in incendiary weapons used in the firebombing of cities in World War II, the only practical civil defense being to smother a burning flare under dry sand to exclude the atmosphere. On burning in air, magnesium produces a brilliant white light which includes strong ultraviolet. Thus magnesium powder (flash powder) was used as a source of illumination in the early days of photography. Later, magnesium ribbon was used in electrically ignited flash bulbs. Magnesium powder is used in the manufacture of fireworks and marine flares where a brilliant white light is required. Flame temperatures of magnesium and magnesium alloys can reach 3,100 °C (3,370 K; 5,610 °F),[7] although flame height above the burning metal is usually less than 300 mm (12 in).[8] Magnesium may be used as an ignition source for thermite, an otherwise difficult to ignite mixture of aluminium and iron oxide powder.
  #10 (permalink)
Old 09-19-2012, 09:17 PM
cparks cparks is offline
2011 Ford Explorer
My Garage
cparks is starting off with a positive reputation.
My 12 Raptor also has black plastic valve covers.
__________________
Clayton Parks - Michigan
2012 Ford Raptor SuperCrew Supercharged 6.2
1957 Ford Ranchero 4x4 428 project
1960 Ford F250 4x4 521 stroker project
2000 Ford Excursion 4x4 V10
2013 Ford Escape
  #11 (permalink)
Old 09-19-2012, 09:33 PM
2012 Ford F-350
No, don't tell me Ford mixup and put a 6.2L Raptor in my F350!
-----Joking-----
  #12 (permalink)
Old 09-30-2012, 11:22 PM
biz4two's Avatar
Arrow
biz
Remembered to post back about the valve covers. YES...they are the new black style. IMHO...not a big deal...but there you have it.
biz
__________________
  #13 (permalink)
Old 10-04-2012, 08:21 AM
Fawcett Fawcett is offline
Fawcett is starting off with a positive reputation.
I've got the aluminum ones in my '12 F350, they're sweet but they are getting kind of ugly looking. I've got to detail my engine bay, they need to be polished or something.
  #14 (permalink)
Old 10-22-2012, 08:10 AM
Racer5349's Avatar
Racer5349 Racer5349 is offline
Racer5349 is starting off with a positive reputation.
Quote:
I did an oil change last week and noticed my '12 F350 has the black plastic covers. Must have switched sometime in '12. I don't know the build date of my truck though.
__________________
Jim
  #15 (permalink)
Old 10-22-2012, 01:53 PM
spud57's Avatar
spud57 spud57 is offline
spud57 is starting off with a positive reputation.
Quote:
If you wanted your build date (Month/Year), it's on the sticker on your door post.
S
__________________
2008 F250 SC LB 4X4 V10
2006 Escape XLT 2WD
2010 Outback 321FRL
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
