drive shaft problem - Ford Truck Enthusiasts Forums
drive shaft problem
Old 09-16-2012, 09:21 PM
zrroper zrroper is offline
zrroper is starting off with a positive reputation.
drive shaft problem
Hey so I have a 77 f100 with a 460 and a c6 auto trans. I am going to change the auto out with a manual np435 transmission. In the process of doing this my drive shaft was to short for my np435 transmission. Does anybody know what size drive shaft I need to get and how I can hook it to the transmission(the drive shaft just slid into the back of the c6 but the np435 don't have a back like that) ?
Old 09-17-2012, 02:18 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
long bed or short bed??
Old 09-17-2012, 02:20 AM
It's a short bed
Old 09-17-2012, 02:41 AM
fordrealdrive's Avatar
fordrealdrive fordrealdrive is offline
fordrealdrive is gaining momentum as a positive member of FTE.
if your np435 has a bolt on yoke you'll need a D-shaft with a stub & slip yoke in order to remove/install D-shaft. most likely you'll have to have one made...you need to measure from one yoke to the other (the flat surface of the yokes, not the pocket that the U-joint sits in)
since you have a shortbed I don't think you will need a carrier brg. ...more $$$ if so
Old 09-17-2012, 11:06 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
ALL 1968/82 460's came w/a C6. 1983 first year 460 was available w/a M/T (and 4WD), F250/350 only.
Driveshaft center support (carrier bearing is a misnomer) only used with two-piece driveshaft. No short bed has a two-piece driveshaft.
Old 09-17-2012, 11:49 AM
mikeo0o0o0's Avatar
I looked in the Ford parts catalog and, as Bill said above, there wasn't a 460/NP435 listed so I can't give you a driveshaft length.
With the flange style mount on the transmission you'll need the driveshaft, the slip yoke and the flange that bolts to the transmission.
Here is the illustration from the Ford parts catalog showing what you'll need for factory style set-up.
Click on the .pdf link.
c6 to np435 swap questions swampthang 1973 - 1979 F-100 & Larger F-Series Trucks 5 04-13-2016 12:16 PM
Transmission NP435 T_Cooksey88 1973 - 1979 F-100 & Larger F-Series Trucks 14 03-10-2016 06:25 PM
NP435 T_Cooksey88 Clutch, Transmission, Differential, Axle & Transfer Case 1 03-06-2016 12:46 PM
NP435 or ZF5 in a 78-79 Bronco ManfredVonRichtofen 1978 - 1996 Big Bronco 6 09-16-2013 06:40 PM
Drive Shaft Lengths 1975MudRat 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-10-2012 11:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
