I-6/4.9 engine, right? They have a fiber camgear that sometimes breaks. that is why you check for rotor button movement when cranking the engine. If thats not it maybe timing has slipped off somehow?
Yes its the 4.9. I was wondering about the timing but I doubted it could be that. The weird thing is that after it starts up finally, if it starts up, it runs completely fine.
there was a tech bulletin about them, gonna bet thats it. or the switch its self. (i have a single tank and when i disconnect that plug it will just crank over and over, great lil cheap security)
Woke up today and tried the truck and nothing. Went to auto zone and picked up some spark plugs and spark wires, put them in and still nothing. Tried the rear tank but I didn't even hear it prime. Put it back to front tank, turned key to accessories for 10 seconds because I hear it does something lol, then after about 30 seconds of cranking it starts up. Take it to orielly to get an obd scan, comes up with the egr valve is closed, coolant sensor temp is low or something like that, and a secondary fuel pump valve or something failure. Now the truck won't start again and I have no clue what's wrong.
Based on these symptoms, it sounds like the in-dash switch is "failing" and not totally "failed".....ie. intermittant connections.
"So that may still be the cause even though it sometimes starts after a while, and runs completely fine after it starts?"
Yep !!
