need help with pitman arm install
Old 09-16-2012, 05:06 PM
2323foru's Avatar
2323foru
2323foru is offline
Replaced my steering gear box and everything seemed to be going o.k.. Removed the pitman arm without removing from the arm. Problem is when I try to put the pitman back on the new steering gearbox it does not line up correctly. It is close but the angle is a bit off. Do I have to remove the pitman arm from the lower arm also ? If so, is that a ball joint ? it appears to be and I have no experience with that. Any help appreciated.
Old 09-16-2012, 06:05 PM
fordmanva's Avatar
fordmanva
fordmanva is offline
dont know if you need to remove it but that is considered a tie rod
Old 09-16-2012, 06:09 PM
CountryBumkin's Avatar
CountryBumkin
CountryBumkin is offline
Is your truck lifted. If the angle is off you will be putting stress on the linkage when/if you do get it installed. For lifted trucks they make a "drop pitman arm".
If the truck is not lifted you may just have too much load on the linkage try lifting one wheel so the linkage (tire) can move a bit.
Old 09-16-2012, 07:34 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
...actually, it's a drag link.
When replacing my steering box last weekend I had a devil of a time keeping the steering wheel centered and the wheels straight ahead.
Didn't pop the Pitman Arm off though.
Lots of unlocking the steering and moving it one notch, then climbing back under.
How many turns lock to lock is your box?
Old 09-16-2012, 08:26 PM
2323foru's Avatar
2323foru
2323foru is offline
I finally got it. Just kept moving the steering a little at a time.. geesh.. aggravating .. anyway thanks for the responses.
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,654 Likes on 1,337 Posts
The splines are going to have to be dead on for them to engage. I would go to harbor freight or somewhere else cheap and buy a pickle fork, and take it loose from the linkage. This is the long piece of metal with a tapered fork on the end that you drive inbetween the joint to bust it loose. It may damage the rubber boot though, that's the only drawback to the pickle fork method.
r1ckyb0nd
1999 to 2016 Super Duty
02-06-2023 04:51 PM
Justforfishing
20
04-07-2018 11:59 AM
fordguy300
03-21-2009 12:52 AM
67FLAT4
07-02-2002 11:33 PM
Quick Reply: need help with pitman arm install
