6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
What parts can be removed from a 6.4 ?
Old 09-16-2012, 12:42 PM
parkland's Avatar
parkland
parkland is offline
If you are tuned, have a tuner, how many parts can be scrapped off the engine?
We know yes, for:
EGR coolers
Intake elbow
DPF / exhaust
stock turbo
EGR valve
What about the fuel cooler?
Is it needed, or just used to stabilize the fuel temperature for emission reasons?
It would be nice to hack that crap out.
Anyone have any other ideas on what could be ditched from the engine bay?
Old 09-16-2012, 09:52 PM
UGA33's Avatar
UGA33
UGA33 is offline
You can remove it. There is a great thread on PSA about it.
Old 09-19-2012, 10:40 PM
RM2738's Avatar
RM2738
RM2738 is offline
Not sure I'd remove the fuel cooler. High temp diesel has a different density and potentially loses some of what's left of the lubrication properties. Extreme pressures of the HPFP (I've heard up where of 20,000 PSI in the 6.4) cause high temps.
Old 09-20-2012, 12:29 AM
parkland's Avatar
parkland
parkland is offline
I think the 6.4's fuel system was advertised up to 28,000 psi.
I am not sure if the "fuel cooler" is so much a cooler, rather a "temperature stabiliser"
Would be interesting to see what happens temp wise without it.
what is "PSA" ?
Old 09-20-2012, 05:42 AM
RM2738's Avatar
RM2738
RM2738 is offline
what is "PSA" ?
I believe he's referring to Powerstrokearmy.com
Old 09-20-2012, 06:26 AM
R-T0r21on's Avatar
R-T0r21on
R-T0r21on is offline
The fuel cooler also keeps the turbo cool. I would'nt remove it. You certainly gain nothing by removing it.
Old 09-20-2012, 08:55 PM
parkland's Avatar
parkland
parkland is offline
This turbo doesn't have liquid cooling does it?
I thought it was just oil cooled?
Old 09-21-2012, 12:43 PM
vloney's Avatar
vloney
vloney is offline
what is "PSA" ?
The sensor under the pipes is the fuel temp sensor. If fuel gets too hot, it derates horsepower.
Old 09-21-2012, 06:53 PM
senix's Avatar
senix
senix is online now
Received 1,416 Likes on 1,011 Posts
28K psi and some change for the fuel pressure to the rails.
Leave the cooler.
Old 09-21-2012, 07:06 PM
RM2738's Avatar
RM2738
RM2738 is offline
I can't find anything on temperatures of diesel fuel at those extreme pressures but, I do know that typical No 2 diesel will usually Auto Ignite at +-270 degrees pending elevation above/below sea level. So, at 28,000 PSI, how hot does the diesel get?
Old 09-21-2012, 07:35 PM
slowmans's Avatar
slowmans
slowmans is offline
you would need oxygen to ignite it though....
Old 09-21-2012, 08:19 PM
parkland's Avatar
parkland
parkland is offline
Yes you would, and also liquids to not simply jump in temperature from being compressed.
I'm not sold that the cooler is even acting as a cooler, I think it's just keeping the fuel warm, and stable, for emissions purposes only.
Old 09-22-2012, 01:31 AM
UGA33's Avatar
UGA33
UGA33 is offline
The pump for the fuel cooler/VGT actuator kicks in when fuel temps get to 160* fuel temp. Think a motor derate comes in at around 200* fuel temp. If you are trying to clean the engine bay up, do a cooler like the Duramax's have down by the fuel tank.
Old 09-23-2012, 02:39 AM
parkland's Avatar
parkland
parkland is offline
OK so I did a bunch of forum reading, and asked a few people as well.
I have a verdict now.
The fuel cooler is required, but the heat isn't generated by the pumps or anything, it's just the under hood temps and engine temps that raise the temperature.
The fuel that doesn't get used goes back to the bowl, so it can build up with heat.
If it went back to the tank, a small passive air cooler would be enough.
The vgt actuator also is cooled by this secondary cooling system.
What a frickin nightmare, I would love to throw a single turbo in and delete all that junk.
It would be awesome to delete the entire 2nd cooling system.
Old 09-23-2012, 06:19 AM
senix's Avatar
senix
senix is online now
A single turbo and getting rid of all the plumbing would certainly clean it up. There might be an aftermarket answer for that I don't know.
Quick Reply: What parts can be removed from a 6.4 ?
