1980 Ford F-100 4x4 Conversion
Old 09-17-2012, 11:37 PM
Bwillden24's Avatar
Bwillden24
Bwillden24 is offline
I live in Medford and I'm working on doing a 4x4 conversion on my 2wd F-100. I have everything but new (j-yard) radius arms, rear driveline and I need to find a new outer shell for my NP-208 transfer case. The t-case is married to an NP-435 and comes with front diff, 3rd member, front driveline, both IFS axles, 3-4" lift (front/rear), Warn Hubs, dual shock setup, add a leaf, axle shafts and several misc parts. I'm only doing the conversion for an as needed scenario, I'm not looking to go wheeling or anything. I got the 300 4.9L L6 and have done a lot of work to it. After I get all the parts I need for the conversion, what kind of things should I do to ensure everything is going to work how it should or what I should do before/during/after the whole conversion?
Old 09-19-2012, 09:25 AM
bertha66's Avatar
bertha66
bertha66 is offline
That is a big project, I know on the older trucks, that the frames are so different between a 2wd and a 4wd, that makes it very hard to convert one. I have a 80 Bronco with the IFS, I have not looked at a 2wd to see what is different about them. Post pictures of your project to see how it is going.
Old 09-20-2012, 05:52 PM
Bwillden24's Avatar
Bwillden24
I'll post pictures as soon as I can so you can see the progress I have made. It's going to take me a little to get it done because the truck is my daily driver.
Old 09-20-2012, 05:59 PM
import killer1's Avatar
import killer1
import killer1 is offline
speaking of 4x4 80s trucks,does anyone know if a small block c6 transfer case will work on a big block c6?
Old 09-20-2012, 06:03 PM
bertha66's Avatar
bertha66
bertha66 is offline
Sense it bolts to the tail of the C6, which should be the same, SHOULD be. Check to see if it transfer cases are the same type.
Old 09-21-2012, 06:53 PM
import killer1
Well that's what I'm worried about,the big block c6 I can get is a two wheel drive model.
Old 09-21-2012, 07:28 PM
bertha66's Avatar
bertha66
bertha66 is offline
You can have the tail shaft changed to fit a transfer case
Ctkallday666
03-13-2011 04:29 PM
88_F-150
01-05-2010 12:32 AM
TwoX
15
04-21-2007 09:51 PM
underdog76
11-30-2003 11:04 PM
jmarro
01-21-2001 07:30 PM
Quick Reply: 1980 Ford F-100 4x4 Conversion
