I need some help. I took the emergency brake bracket that mounts to the frame apart a couple years ago and now I can not remember how it goes. If anyone has nay pictures I sure could use some help.
Here's what I have in my photo archive. Not sure if it's helpful. I just sold this bracket and should have taken detailed pictures. If no one else posts detailed pictures, I'll take a picture from the part manual and post it later.
I had the same problem, just not ready to tackle it yet. Those pictures helped a lot. I saved them where I can find them. Thanks Ilya.
BTW the cables were gone but the other hard parts were very corroded, but soaking them in vinegar and water for a couple days then using a wire wheel cleaned them up pretty well. I then painted them with Rustoleum Aluminum and they look pretty good. I'll add pictures when I dig them out and install them again.
