Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > California, Southern Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
California, Southern Chapter Join Chapter, Leader: wpnaes
  #1 (permalink)
Old 09-15-2012, 11:06 PM
djed djed is offline
2001 Ford F-350
djed is gaining momentum as a positive member of FTE.djed is gaining momentum as a positive member of FTE.
Need Help Identifying Part
OK - here goes.
The oval window in the front of my bed is missing. You can kind of see half of the oval window in the top middle of this picture:
Click the image to open in full size.
I need to get the rubber gasket that holds the glass in place but don't know what it is called and where I can purchase it. (? A glass shop ?)
An example of the gasket holding in a window can be seen in the doors in the next picture:
Your help in the name of the gasket-like rubber piece and where it can be purchased would be appreciated.
David
  #2 (permalink)
Old 09-16-2012, 09:06 AM
wpnaes's Avatar
wpnaes wpnaes is offline
FTE SoCal Chapter LDR
2000 Ford Excursion
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
I'd guess that's a generic window gasket. I'd start at an auto glass shop and go from there.
Realize this is in the UK, but has some good pics of options avaliable...
http://www.sealsdirect.co.uk/shoppin...DepartmentId=4
__________________
Sean
2000 Excursion XLT V10 4x4 170K, front V's, rear mod'd C's,, 315's, winch bumpers F/R, Viair system, Piaa lighting, Hellwig rear, dual Optimas, oily K&N, RedHeaded, scratchy paint, love taps at each corner.
Join the So Cal chapter here
  #3 (permalink)
Old 09-17-2012, 12:44 AM
OldBlackCat OldBlackCat is offline
2003 Ford F-250
OldBlackCat is gaining momentum as a positive member of FTE.OldBlackCat is gaining momentum as a positive member of FTE.
i would goto whom ever built your service body.... another place to maybe try and call is "truck Depot" there in van nuys. they purchase repair and resell used work trucks, they could point you in the right direction.
p.s. im curious on how you have a car license plate on a truck....
__________________
Justin
2003 F-250 XLT SC/LB 4x4 7.3L Auto 210k Miles lifted 6" on 35's
  #4 (permalink)
Old 09-17-2012, 01:22 AM
2001 Ford F-350
Thank you for the referral to Truck Depot in Van Nuys. I'll give them a call this week.
The service body was built in Washington for an electric company that did work for the local utility companies. I suppose I could give them a call to see about the window gasket material.
Not sure about the license plate. It was there before I bought it and that's how I registered it with DMV after I purchased it.
I didn't realize these trucks had license plates different from cars. I guess I've got another research project.
  #5 (permalink)
Old 09-17-2012, 08:16 AM
2003 Ford F-250
heck the mfg. of the body may have the glass too they can ship to you.
on the license plate, usualy all pickups and trucks, big rigs, etc have plates with just one letter then numbers. trailers have two letters with numbers on there plates and cars/ suv's have three letters and numbers.
__________________
Justin
  #6 (permalink)
Old 09-17-2012, 08:24 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by OldBlackCat View Post
I'm curious on how you have a car license plate on a truck.
If a truck has a permanently attached camper shell or slide in the bed camper, or a camper mounted to frame rails, it does not require commercial plates.
However, this is a service body, not a camper. A sneaky so and so passed it off as one to avoid expensive to register commercial plates (2012: renewed tags on 2011 oversized tub in sig pic: $325.00).
If a cop sees that non commercial plate, finds a tool inside, be prepared to pay a big buck fine!
btw: Tonneau covers don't count. I found this out the hard way after salesman said: "Just install a tonneau cover, then you won't need commercial plates." Car/truck sales peeps lie like rugs, this one was also clueless.
I've had the same DP plates since 2001. When installed on a truck, they automatically become commercial plates. Welcome to California!
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #7 (permalink)
Old 09-17-2012, 09:22 AM
william_04_x's Avatar
william_04_x william_04_x is online now
Interstate Menace
Garage is empty, add now
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
An RV parts supplier may also have that gasket material in bulk. Trailer windows are held in place similarly.
  #8 (permalink)
Old 09-22-2012, 01:43 AM
2001 Ford F-350
To close the loop on this, I picked up dual channel rubber window moulding from Skaug Truck Body Works in San Fernando.
I had originally called asking what the product was called and where I could source it and the owner said he had an old box laying around that he hadn't used in 20 years. He gave me what I needed at no charge.
I'll source the window material (probably from Gavrielli Plastics in North Hollywood) and post a picture when I'm done. I was going to use tempered glass but there is just no reason to do so since I can't see out the rear view mirror and I'm assuming plastic will hold up to stuff bouncing around the bed better than glass.
Thanks again to the guys at Skaug.
  #9 (permalink)
Old 09-22-2012, 02:27 AM
2003 Ford F-250
my dad worked for Skaug about 45 years ago! building truck bodies.
__________________
Justin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
