Oversize and overlength door hinge pins?
Old 09-15-2012, 05:55 PM
aussiecowboy's Avatar
aussiecowboy
aussiecowboy is offline
I need a set of oversize hinge pins for the upper door hinges on my 49. The problem is I am planning to run mirrors on the hinges rather than screw them to the doors like the original. I can find oversize ones and I already have the longer ones but I can't find both. Has anyone come across these?
Old 09-15-2012, 07:32 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
An idea - Try to find out who is making the pins - As limited a use that there is for them I would imagine that there are only one or two making pins for all makes of old vehicles
Figure out what size you need and contact the manufactures and see if they make one that will fit your need
The other way is get a small machine shop to make up a set and get then hardened to the right spec.
Old 09-15-2012, 09:07 PM
F1 48 Ford's Avatar
F1 48 Ford
F1 48 Ford is offline
I just added mirrors to my hinges on my 48 F1.I bought mine from Bob Drake in Oregon and they came with the right pins.I ordered two more pins for the lower hinges and had to cut about one quarter inch for the right length.I think the pins were .280 and they fit the hinges perfectly.The doors now fit great now with no with no slop in the hinges and I can see whats behind me.
Old 09-15-2012, 09:21 PM
aussiecowboy
I got the mirrors from Dennis Carpenter, going by the part number it's probably the same as Bob Drakes. The 0.28" is the standard pin measurement, the oversize ones are 11/32 which works out to 0.34". I already fitted the door with the 0.28" pins and the rear of the door has about 1/4 to 3/8" play just from hinge slop, not good when trying to get panel gaps right.
Old 09-17-2012, 02:19 PM
aussiecowboy
It's amazing what a few hours on the internet can do. I hunted around and found two possible solutions.
The first is another set of pins from a GM car, they are the correct 11/32" oversize diameter and are 4 1/16" long with the correct spline under the head. Cut them to lenght and they should work fine.
The second is a set of bushes from a Chrysler, they have a 1/4" ID and 3/8" OD. I'll be able to ream the hinges to take the bushes and then ream the bushes to take the original size of pin.
Not a lot of money so I have ordered parts for both options, I'll see which will work best and go from there.
Old 09-17-2012, 02:34 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
Sounds like a good deal
For the benift of others, uncluding me, could you post the part numbers and the source for the pins and bushings - Thanks
Old 09-17-2012, 02:46 PM
aussiecowboy
Sure, the supplier was ClipsAndFasteners.com - Automotive Retainers,Clips and Fasteners.
The bushing was part number A17167
Door Hinge Bushing
O.D.: 3/8"
I.D.: 1/4"
Length: 13/32"
Flange O.D.: 1/2"
Replaces Chrysler: 4336115 Aries, Caravelle, LeBaron, Reliant, Town & Country and 600 1989-85 Front & Rear Doors
The pin was part A14559
GM Door Hinge Pin 4-1/16 Length 11/32 Pin Dia
Old 09-17-2012, 04:22 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
Thank you
Info bookmarked
info filed in a place I'm sure to lose it.
Old 09-17-2012, 04:55 PM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
Thank you cowboy for the site info, I see a lot of items to clean up my wireing.
Old 09-17-2012, 05:01 PM
aussiecowboy
I was impressed with the site also, I ordered yesterday, was able to pay via paypal and got an email this morning saying that it has been shipped, service doesn't come much better than that.
drptop70ss
03-26-2014 03:50 PM
jjurva!
07-27-2013 02:38 PM
ralphhood3
25
01-07-2012 07:01 PM
windsurfer
05-29-2007 03:27 PM
billb7984
1947 and Older Ford Trucks
11-06-2002 11:18 AM
Quick Reply: Oversize and overlength door hinge pins?
