fire roasted 'stroke
Hey fellas! First, thanks again to you guys that took time to try to answer my stupid questions last couple of time I was in here. The 7.3 'strokes been a learning adventure, and I'm coming along. Here's my next dumb question:
When I bought this truck (01 F250 2wd spd) the PO threw in a spare motor. Neat, huh? Well maybe. I'm told it came out of an 01 F550 that was in a shop fire. The compressor housing, accessory brackets, and a/c compressor are severely deformed. The front cover, oil reservoir, and valve covers are not deformed. The injector connectors are melted away, but the solenoids are intact. I pulled the glow plug and injector from #2. The glow plug (a Beru) is nearly pristine and works great. the injector came out loaded with engine oil, and all o-rings and seals intact. There was still oil in the oil pan (which is now all over my shop floor- ugh) I don't know anything about the engine's condition or history prior to the fire, but based on the admittedly sketchy description, and not withstanding any prior damage, you guys have any thoughts on how much of this motor (block, heads, crank, pistons, etc) might have survived? Bear in mind I have no thoughts of trying to set it up and run it as-is. At minimum, I should think rings, bearings, gaskets, and a good cleaning.
If it was in a fire, I would assume that most of the rubber seals that are kind of important are going to be compromised. The front cover may look fine, but what about the o-ring gasket behind it?
Pull the pan and pull the heads and take a closer look at things. If it were me, I'd just order a rebuild kit for it. Or build it up to be a higher HP motor as a project that you can drop in your truck down the road.
Yeah, Chris, I figured at a minimum it would need to be torn down, wash out good, and a good set of rings, bearing, and gaskets. Obviously all the sensors and actuators and a rebuild and set of solenoids on the shooters. I guess what I'm most concerned about is whether or not the major components (crank, block, heads, pistons, cam, etc) might be useable without a lot of remachining. on the face of it, all that twisted aluminum looks like a trip through hell, but then there's all that engine oil still in it. Makes me think maybe the heat didn't penetrate all that deep. Maybe a short-lived fire?
Yup... rings, bearings, seals, new freeze plugs..
Maybe a new oil cooler depending on how long the fire was burning...
Truck fires are crazy hot... let alone a shop fire with a truck in it catching fire.
Alternator/s, starter, did the power steering pump survive at all?
Isnt there a seal inside the water pump ?
If your going that deep into it tho... im sure you will find any issues that may arise...
Take your Alternator/s and starter up to napa and get them tested... they usually do it for free. Heck i think most parts houses do it.
Pictures... you gotta show us this motor that took a drive through west hell...
Xtof
Xtof
I'll try to get some pics up later if I can figure out how. All the accessories are either gone or roasted. If I end up needing the motor, I'll just transfer the accessories off the one in the truck. Just changed the WP. Saw a kit somewhere for $1400 that looked to have rings, bearings, gaskets, and pistons. Kinda hopin the pistons are ok, though. Hadn't thought about the freeze plugs or cooler. I'm sure it'll at least need O-rings.
clint stafford
08-28-2014 06:41 AM
r_reed
11-26-2007 11:25 PM
SoccerFetus8
02-01-2007 05:37 PM
racetrips
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
01-07-2005 09:17 PM
