Turn over Flathead by hand - Ford Truck Enthusiasts Forums
Old 09-15-2012, 04:20 PM
lvs2fly lvs2fly is offline
lvs2fly is starting off with a positive reputation.
I have a '51 Ford F1 that has not been started since 1975...I'm trying to start it just to see if it will start before I rebuild it...I've soaked the cylinders with oil twice...what is the best way to turn it over by hand. It's tore down to the engine and cab, so getting to everything is pretty easy. I did try bumping the starter, but it just spins and won't engage. Any help would be appreciated! It's my first project like this, the truck belonged to my grandfather, he bought it new in 1951 and it's been in the family ever since. Thanks!!
Old 09-15-2012, 04:35 PM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
Get a socket that fits the crankshaft bolt, use a breaker bar, and try turning it clock wise. If it don't turn, don't force it, remove the heads and check for cracks between the valves and cyl's. It may have stuck valves too.
Old 09-15-2012, 09:30 PM
Success!! That worked...can't beleive it turned over...I turned it about 25 times. Thank you!!
just wont start coop3636 2009 - 2014 F150 2 04-15-2016 05:12 AM
6.0 full power no start. Was cranking and POPED BrandonLee 6.0L Power Stroke Diesel 34 04-11-2016 07:24 PM
Steering issues bielaf 1999 - 2003 7.3L Power Stroke Diesel 7 04-23-2014 08:12 PM
no crank no start help tried everything Grady Whitman Expedition & Navigator 3 02-15-2014 02:15 PM
Having trouble starting my '67 F100 w/352 willdogs4286 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 10-19-2013 12:53 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
