Rear End Swap - Ford Truck Enthusiasts Forums
Rear End Swap
Old 09-14-2012, 02:54 PM
Eaglekiller Eaglekiller is offline
Eaglekiller is starting off with a positive reputation.
Rear End Swap
1969 Ford F100, Looking for a rear end swap to upgrade to disc and limited slip? Not sure there is a option but going have 400hp+ and considering 4 link. So want to look at a swap as opposed to just adding disc to what came stock, I would but want to spin both tires not just one
Old 09-14-2012, 03:29 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Not exactly a bolt-in swap since it's a Bumpside but what you'll want to aim for is a Ford 9-inch with 31-spline axles and a Detroit Locker or Detroit TrueTrac. Depending on its planned use, also consider 35-spline axles, 1350 U-joint, and a yoke by Strange or Moser.
4-link? Ya'd better know how to weld or are in good with a fab/race shop. Otherwise, call Currie Enterprises (cha-ching, cha-ching).
Old 09-14-2012, 04:54 PM
instig8r63 instig8r63 is offline
instig8r63 is gaining momentum as a positive member of FTE.instig8r63 is gaining momentum as a positive member of FTE.
You do not need nor will you benefit from rear disc brakes in a 70's truck. For a posi, buy a Detroit Locker and call it done. You'll benefit more from a 73-79 front disc brake conversion than you will from a rear disc set-up.
Why do you want a 4-link? Is this a straight line truck or a daily driver?
Old 09-15-2012, 06:53 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1968/72 F100's offered two different 9" rear axles. The Dana 60.3 (not a Dana 60!) with Limited Slip was also available. Dana's have an inspection cover, 9's do not.
1) 9" with 28 spline axle shafts with or without Limited Slip. 3,300 lb. rear axle capacity.
2) 9" with a 9 3/8" ring gear, 31 spline axle shafts with Traction-Lok. 3,600 lb. rear axle capacity.
9 vs 9 3/8: Only 5 parts are the same: Housing gasket, one pinion bearing and race, pilot bearing retainer and the pinion seal. EVERYTHING else is different!
1973/79 F100, 1975/79 F150: Some have 28 spline axle shafts, some have 31 spline axle shafts. Some have Limited Slip, some do not.
1973/79 F100/150's have wider rear frame rails (behind the cab) (37 1/2") than 1961/72 F100's (33 1/2").
Some 1974/79 9's have a tapered roller axle bearing/seal combination. 1973's, some 1974/79's have a ball axle bearing, separate seal.
And, some 1976/79 F100/150's came with Dana 44 rear axles with or without Limited Slip. If you see an inspection cover, pass!
If the AXLE code stamped on the Warranty Plate begins with a letter: Limited Slip / If with a number: No Limited Slip.
Old 09-17-2012, 01:35 AM
So I ordered the wide ride IFS coil over from no limit this Friday and will pick up in a couple days. Considering the drop spindles? I have been doing some research it seems once I pick the gears adding a Detroit locker or similar is the right move. This isn't my daily driver just something for fun on weekends!. Got my work area set up truck on dolly work begins tomorrow.
Old 09-17-2012, 01:46 PM
HIO Silver's Avatar
Quote:
Sweet.. Arrightee then. it sounds like this ain't your first rodeo.
Have you decided what to do with the rear end? IRS out of a T-bird/Lincoln perhaps?
Old 09-20-2012, 01:12 AM
My tag on my rear end is hard to read but it says its a 3.70, How can I figure out the Spline 28 or 31? Which 9" rear has a limited slip I can grab the pumpkin? Or grab the whole thing and get Disc brakes?
Old 09-20-2012, 01:15 AM
Added the no limit rear kit for coil overs. Will have power brakes and power steering when all done.
'72 F250 front end swap? rsirrin 1967 - 1972 F-100 & Larger F-Series Trucks 5 03-10-2015 03:39 AM
Rear Disc Brakes GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 01-09-2015 11:21 AM
Dana 60 rear disc brake? bucks77ford 1973 - 1979 F-100 & Larger F-Series Trucks 11 04-02-2014 07:55 AM
8.8 rear disc brake swap Bootlegger's Deluxe 1987 - 1996 F150 & Larger F-Series Trucks 19 11-27-2012 06:14 PM
1997 dually rear disc brakes fordmaniac1 1987 - 1996 F150 & Larger F-Series Trucks 8 04-02-2012 09:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
