9 INCH REAR AXLE BEARINGS AND SEALS HELP ME PLEASE
I need to get the correct part numbers to replace the axle bearings and seals on this 9 inch. I will be at Gary's GTG saturday and we are working on rebuilding this axle. Here are the pictures. Gary said this setup looks different than his. Anyone got a clue what part numbers I need?
A20 at oreilly.
http://images.oreillyauto.com/parts/.../mpb/pta20.jpg
http://www.oreillyauto.com/site/c/de...0055&ppt=C0337
That's the taped roller bearing with outboard seal. The seal *should* come with it.
There's still a race (cup) in the end of the axle housing. Whatever housing that axle came from, as I don't see it in the pic....
A20 at oreilly.
MasterPro® Bearing/Seal A20 - Wheel Bearing | O'Reilly Auto Parts
I bought the bearings, third member seal, some full synthetic gear oil and some carb cleaner to clean out the third member real good before reassembly. Im going to check the lash on the gears tomorrow night and install the third member and apply the POR15. That way all we need to do saturday is press on the bearings and install the backing plates and axles. I will swap out the axle Sunday if my pregnant wife allows me some more time. Or if we get bored Saturday night we could swap it out then
fatheroftwo
03-10-2016 11:56 AM
volks
05-24-2010 11:09 PM
1975Ford
15
11-21-2005 11:19 AM
Greg 79 f150
09-23-2004 07:40 PM
