sloppy shifter?? did we brake something?
my mom's 95 shifter is slowly getting worse. right now it's at the point where we have to hunt for gears just to put it into park or reverse or d/od. it's not stiff like the rest of ours, hers is all sloppy and loose. she says it's been doing this for a while, but i think it got worse when i pulled her cluster out to change the light bulbs. I say this because i couldn't get the needle cable un done, so i just let the cluster rest on it while i was changing the bulbs, which put a little bit of tension on it.
HA!!! my girlfriend figured it out. if it werent for her probably would have torn the steering column all apart to figure it out, since i had to wiggle a weird way to see that the bolts at the end of the shifter were both loose. she's smaller than i am, and was able to see them right off the bat.
any ways it was the two bolts shown in the picture below that had wiggled loose and was making the shifter all sloppy.
hopefully this thread will help others in the future
I think both. my mom said that she had been lazy and was just dragging it around, i told her not to do that because it will cause this plus could cause the shifter to brake... we had to replace one once in my dad's old 94 (rip) and it wasn't cheap, and that was ten years ago (like 200 bux)
[quote=DCRB;8049876]HA!!! my girlfriend figured it out. if it werent for her probably would have torn the steering column all apart to figure it out, since i had to wiggle a weird way to see that the bolts at the end of the shifter were both loose.
Hey DCRB
Thanks so much for posting your fix. I have had the same problem with my 96 F150, and was just about to take the column apart when I read you post. Just fixed it and all is right again. Made my day.
Hey DCRB
Well I finally got around to getting under the dash and that was it. The bolts were both very loose. Good call on this fix.
For those that may have this issue also and are having a hard time finding the bolts we are talking about on the shifter linkage. It is located just above and forward (toward the diriver) of first steering shaft U-joint.
I echo Don S's response. Good call on this one. I had replaced the shifter a little while ago, so was pretty sure that there were simply some screws loose- well besides the ones in my head... Crawled underneath, and sure enough, those two bolts were loose. T-27 star bit fit, no need to remove anything. 5 minutes, and it was done. Thanks!
