PCV for an 8BA
Old 09-30-2007, 11:29 PM
frb9883's Avatar
frb9883
frb9883 is offline
PCV for an 8BA
After removing the oil pan and the intake manifold I found the beginnings of sludge. I would like to install a PCV system to help eliminate this problem. What's the best way to do this.
Thanks,
Frank
Old 10-01-2007, 12:33 AM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Panties NOT in a Twist
Not sure which engine you have,or what that number designation is in your byline.I have a 292 in my 59 250.The old man(original owner) rigged a pcv system thusly:He totally plugged the roaddraft down tube with silicone,installed an adaptor w/pcv valve in the top portion of the roaddraft tube,then ran a hose from pcv valve to the port which is in the carb spacer.
Not being sure of that method's effectiveness,I unplugged the down tube, removed the pcv valve but did leave the hose between carb spacer port and top of roaddraft tube.I have a newer valley pan which has provision for a pcv valve.When I eventually get around to installing that,all I should have to do is remove the end of the hose from the top of road draft tube(plug up the hole) and put it onto the pcv valve at the new location in the new valley pan.I hope that is helpful,and I hope my plan is correct.If I'm wrong,someone will let me know directly!Steve.
Old 10-01-2007, 12:36 AM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
After the above post,noticed in your profile you have a flathead.Disregard the above.I'm always doing things backwards.Some one will be along soon with the correct help.Steve.
Old 10-01-2007, 12:42 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
It's real simple and costs about $10. The parts I used are:
Help! grommet #42052 (it's for some GM car)
Fram PCV # FV294 (Buick 3.8L I think)
I got an AN fitting to match the vacuum port on the manifold (just under the carb), and some 3/8" ID hose. Shim the grommet a little to make it fit tight in the draft tube hole. Looks like this:
Old 10-01-2007, 04:26 AM
55 f350's Avatar
55 f350
55 f350 is offline
i was gonna suggest gonna suggest rattling albuq's cage as he answered this before and it's still on my list of things to do . but as usual he's right on it !
Old 10-01-2007, 08:33 AM
F6Guy's Avatar
F6Guy
F6Guy is offline
Damn good looking engine!!!!!
Old 10-01-2007, 05:19 PM
5 Star's Avatar
5 Star
5 Star is offline
ALBUQ F-1
Good lookin set up you have there, I just want to add another way different intake.
I did up a 39 Ford with an 8BA Block, 59A Heads, and Cam. I wanted this engine to look as though it was an Engine of that period.
Now onto the Intake, I used an Offenhauser with 2 Carbs, and ran my stock Gen, which has the Fan on the end of the Pulley.
To get the PCV setup we had to cut the pipe which sits up into the stock 8BA Intake, just a little as there is no provision for it to fit into the Offenhauser. Anyway just at the Top of the Intake we drilled a hole and tapped it, to accomodate a Chrysler threaded PCV and ran it the same as you did to the bottom of Carb.
Just thought I would add this in case someone ran into this situation.
Old 10-01-2007, 06:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by 5 Star
ALBUQ F-1
A guy on the MSN flathead forum went a step further, using the same 8BA/59AB setup you did. He capped the tube that runs up from the crankcase, soldered/brazed a fitting on the side of the tube horizontally, and put the PCV valve under the manifold completely, feeding a hose to a fitting he tapped into one of the runners on the bottom of the manifold. No sign from the outside that it is even there.
Got a pic of your flatty?
Old 10-02-2007, 04:39 PM
frb9883's Avatar
frb9883
frb9883 is offline
Great idea. A lot simpler than what I had planned. The only photos I have of my engine are at home and I'll try to send them tonight. In the photo the engine is on a stand with the stock trans. Since then I've installed a T-5. Six years of work and I'm finally getting close to driving it.
Old 10-02-2007, 08:31 PM
5 Star's Avatar
5 Star
5 Star is offline
Ross, that Flattie that I did was a few years back and when my computer crashed, all the pics disappeared.
Still have the pics in my mind but can't post em.
Old 09-29-2012, 05:29 PM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
Um Ross just curious does that pcv set up keep the oil vapour off your engine that well or did you just wash it for us .
Old 09-29-2012, 05:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It actually does keep the oil vapors completely at bay. The engine leaks a little more than I think it should at the rear main, I'm thinking it's building some pressure at higher RPM's so that was part of the reason for upsizing the holes in the manifold. Time will tell...
jdq
2009 - 2014 F150
02-27-2017 08:53 AM
NS70250
33
08-17-2016 11:50 AM
BAJI26
03-16-2008 01:24 PM
randy6800
1983 - 2012 Ranger & B-Series
03-13-2008 07:06 PM
harryvil
Escape & Escape Hybrid
09-18-2007 07:08 AM
Quick Reply: PCV for an 8BA
