IRPs high flow coolant filter opinions
Im looking for a coolant filter system and came upon the IPR unit. What do you guys think of it, I like the way it moves a lot of coolant off the manifold through the filter and it has a clean look. It is plumbed into the coolant loop affording more volume of coolant being sent into the filter. I know it's a little pricey but so is major engine work.. Opinions ?
Thanks tommy
Thanks tommy
https://www.ford-trucks.com/forums/1...il-cooler.html
That has something in it you might want to read
That is a excellent point, in a Pinch I wonder if you could just remove it until you had the faculties to square it away, I am waiting for Blade35 and bismic to chime in on what they think..
If it's a removable element I would think you can remove that and
put the cover back on and run that way.
IPR High Flow Coolant Filter Ford 6.0
Sean
Sean
The ONLY advantage I see to this is that it has a magnet with a washable strainer. "Full flow" would be easily achieveable for a MUCH cheaper price.
It's a full flow bypass filter run inline with the heater core. If it plugs up, all it will do is take away heat coming into the cab. It will not affect the performance or cooling functions for the engine/oil cooler etc... (I had asked Vince about this already). As for changing/cleaning the filter..... it's a bit messier than on the other bypass kits as it is full flow they do not like to use shut-off valves (as used in smaller hose sized kits on the market now) as they restrict some of the flow. They recommend draining about a gallon of coolant, cleaning the filter and re-installing the drained coolant. To me, this sounds like a pain in the a$$ and I will be using some vice grips hose clamps to pinch off both sides before I clean the filter out.
I also believe their Oil Relocation Kit needs work and I would not recommend it at this time. I have however ordered their Gen II EGR Delete Kit and the High Flow Coolant Filter. I ordered it like 2 weeks ago so the suckers should be here in the next few days hopefully...... takes so friggin long to get anything into Canada!
or
You can run it with your heater core lines..... no damage to the engines cooling system this way. Just blows cold air in the cab if it gets plugged up. This will be the method I am going with.
Jarhead97
11-14-2012 11:56 PM
