A resistor on the IAT sensor?
I have noticed a lot of things on the web on modules that promise increased MPG and power by adding a resistor on the IAT sensor. As much as I like the idea of increased MPG and power for cheap, if it doesn't work, I don't want to waste my time.
So, what is the consensus on this type of modification? Will this mod be effective or only be a wase of time?
Thanks for your thoughts!
What not to use:
https://www.ford-trucks.com/forums/1...vp12-chip.html
A great alternative:
https://www.ford-trucks.com/forums/1...ed-4-14-a.html
Waste of time.
The resistor gimmick has been around for years. It just fools the PCM into thinking the air is a different temperature so it operates the fueling system richer or leaner.
It cannot both increase power (which takes more fuel) and save fuel (which reduces power).
A customized tuner package can allow you to select which attribute you want.
fordfarmer12
1999 to 2016 Super Duty
13
03-14-2012 03:25 PM
