Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 09-12-2012, 11:48 PM
NateTheGreat NateTheGreat is offline
Garage is empty, add now
NateTheGreat is starting off with a positive reputation.
1960 F250 4X4 Disc Brake Conversion
So I have been trying to find a disc brake conversion kit for my 1960 F250 but can only seem to find conversion kits for the 1/2 ton. Any ideas which newer F250s have the same axles as the '60 (Dana 44 front and 60 rear, I believe)? I've heard rumors that a '78 might be compatible but I want to check before I go to the pick and pull.
Thanks in advance.
  #2 (permalink)
Old 09-13-2012, 02:45 AM
Nick02's Avatar
Nick02 Nick02 is offline
Nick02 is starting off with a positive reputation.
78-79 f250's had the best dana44's high pinion, flat top knuckles and two piston calipers. I believe some 76-77's had the same disk brakes but low pinion. should share same frame width as the spring perches, but leaf-spring width may be diffrent. The late model axles have wide spring perches so they are incompatible.
This place sells a kit for the large closed knuckle 8 lug dana 44
4x4 Front Differential Disc Brake Kits
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
