Ford 9-inch rear axle assembly -COMPLETE
Category: Accessories
Price: $1800
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Accord, CRX & pre '92 Civic, '92+ Civic/EL & Del Sol, '06+ Civic/CSX, Prelude, Fit, S2000, Integra & '97-'01 Integra Type-R, RSX & '02-'05 Civic Si, TSX/'03+ JDM/Euro Accord, NSX, FCX, CL, TL & Vigor, Minivan, SUV & Truck, Legend & RL, Motorcycles, Hybrids
Item Condition: MI
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck, Part suitable for diesel truck
Located in Dearborn MI. area...$1800.00 for EVERYTHING!!!
COMPLETE Ford 9-inch rear axle assembly...housing pulled from 1970
F100 truck.
I was going to use this in my 1956 F100 project but things changed in my
life and I was forced to sell the truck......
EVERYTHING is BRAND NEW... unless noted!
I also have the original backing plates for the axle tube end flanges ......
Housing cleaned up...ready to weld-up No Limit 4-bar available separately...
C7AW-E38 Center Section with small carrier bearing...
NEW Dutchman Street/Strip 28-Spline axles!...
Ford Racing Performance Products TracLoc...28-spline...
Currie Trac-Loc specific bolts AND Torco Limited Slip additive...
Includes TWO Daytona (?) Pinion Bearing Supports...the "hooded" one
does NOT have bearings or races...
Visteon NASCAR 9" ring-and-pinion set. Raito is 3:89:1.
Polished and de-burred gears. Ring gear has been back–cut…$$$
Ring and Pinion gears have ONE 400-mile race on them!....PERFECT!!
Ford 9-inch Big Bearing (3.15” Torino) Complete Rear Disc Brake
Conversion kit.
Non Cross-Drilled 11” Rotors with 5” x 4 ½” Ford bolt-circle, “loaded”
GM metric calipers with parking brake and cables, caliper mounting
brackets, original 1970 backing plates, Stainless Flex Hose Kit, new
pads and all hardware……
...ready to just bolt-on to axle tube end flanges (2.375 x 3.50")
Ford 9-inch Big Bearing TIMKEN Overhaul - Rebuild Kit……
Includes ALL NEW;
-Pinion Bearings
-Carrier Bearings (2.890”)
-Pinion Seal
-Pinion Nut
-Pinion Shims
-Copper Housing Washers
-Pinion O-Ring
-Crush Sleeve
-Ring Gear Bolts (1")
-Third Member Gasket
-Loc-Tite
-Marking Compound
ANY questions email me thru this site...OR just call
Brian @ 734-536-2745
I also have TCI IFS, No Limit FatBar 4-bar...BOTH with air bags, plus
Art Morrison Enterprises frame notch mandrel-bent 2" x 4" steel,
ACCUAIR air ride management system with EVERY option available,
12-gallon air tank with 8-ports, plus MORE...
I also have an early '60's Small Block Ford (260, 289, 302 c.i.)
ORIGINAL Buddy Barr/Holley TRI POWER set up with all the original progressive linkage, fuel log and oval air cleaner!...includes
3 HOLLEY rebuild kits AND 3 custom fabbed 1.5" card spacers!..helps
to keep fuel "cool" by adding some air under carb's...
Will be posting MORE soon...or search Detroit-Wayne County under
auto parts & just search my phone number!....
...the 1983 Mustang 5.0L motor & C4 transmission are sold...sorry...
THANKS for looking!......
Akhnot
01-04-2021 07:58 PM
wpnaes
S. California Chapter
133
11-15-2014 09:21 PM
