Ford 9-inch rear axle assembly -COMPLETE - Ford Truck Enthusiasts Forums
Ford Truck Parts for Sale Ford Truck related Parts and Accessories for sale
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Location (State):
Old 09-12-2012, 11:29 PM
rockher_man's Avatar
rockher_man rockher_man is offline
rockher_man is starting off with a positive reputation.
Exclamation Ford 9-inch rear axle assembly -COMPLETE
Category: Accessories
Price: $1800
Private or Vendor Listing: Private Listing
Location (State): MI
Item Condition: Brand New
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck, Part suitable for diesel truck
Part fits:: older-1947, 1948-1960, 1961-1966, 1967-1972, 1973-1979, 1980-1986, 1987-1996, 97-03 F150, 04-08 F150, 09-current F150, 99-current Superduty, Ranger, Bronco, Expedition, Explorer, E-Series Van, Miscellaneous
Items can be shipped...but buyer will pay costs......
Located in Dearborn MI. area...$1800.00 for EVERYTHING!!!
COMPLETE Ford 9-inch rear axle assembly...housing pulled from 1970
F100 truck.
I was going to use this in my 1956 F100 project but things changed in my
life and I was forced to sell the truck......
EVERYTHING is BRAND NEW... unless noted!
I also have the original backing plates for the axle tube end flanges ......
Housing cleaned up...ready to weld-up No Limit 4-bar available separately...
C7AW-E38 Center Section with small carrier bearing...
NEW Dutchman Street/Strip 28-Spline axles!...
Ford Racing Performance Products TracLoc...28-spline...
Currie Trac-Loc specific bolts AND Torco Limited Slip additive...
Includes TWO Daytona (?) Pinion Bearing Supports...the "hooded" one
does NOT have bearings or races...
Visteon NASCAR 9" ring-and-pinion set. Raito is 3:89:1.
Polished and de-burred gears. Ring gear has been back–cut…$$$
Ring and Pinion gears have ONE 400-mile race on them!....PERFECT!!
Ford 9-inch Big Bearing (3.15” Torino) Complete Rear Disc Brake
Conversion kit.
Non Cross-Drilled 11” Rotors with 5” x 4 ½” Ford bolt-circle, “loaded”
GM metric calipers with parking brake and cables, caliper mounting
brackets, original 1970 backing plates, Stainless Flex Hose Kit, new
pads and all hardware……
...ready to just bolt-on to axle tube end flanges (2.375 x 3.50")
Ford 9-inch Big Bearing TIMKEN Overhaul - Rebuild Kit……
Includes ALL NEW;
-Pinion Bearings
-Carrier Bearings (2.890”)
-Pinion Seal
-Pinion Nut
-Pinion Shims
-Copper Housing Washers
-Pinion O-Ring
-Crush Sleeve
-Ring Gear Bolts (1")
-Third Member Gasket
-Loc-Tite
-Marking Compound
ANY questions email me thru this site...OR just call
Brian @ 734-536-2745
I also have TCI IFS, No Limit FatBar 4-bar...BOTH with air bags, plus
Art Morrison Enterprises frame notch mandrel-bent 2" x 4" steel,
ACCUAIR air ride management system with EVERY option available,
12-gallon air tank with 8-ports, plus MORE...
I also have an early '60's Small Block Ford (260, 289, 302 c.i.)
ORIGINAL Buddy Barr/Holley TRI POWER set up with all the original progressive linkage, fuel log and oval air cleaner!...includes
3 HOLLEY rebuild kits AND 3 custom fabbed 1.5" card spacers!..helps
to keep fuel "cool" by adding some air under carb's...
Will be posting MORE soon...or search Detroit-Wayne County under
auto parts & just search my phone number!....
...the 1983 Mustang 5.0L motor & C4 transmission are sold...sorry...
THANKS for looking!......
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Changing the upper (secondary) fuel filter in a 6.0L bismic 6.0L Power Stroke Diesel 56 08-10-2015 11:35 AM
Mods, Maintenance, and Life(long and kind of pic heavy) redman84 1994.5 - 1997 7.3L Power Stroke Diesel 17 05-29-2013 01:38 PM
Just wanted to say.... rockher_man 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 09-13-2012 01:04 AM
MY 1956 F100 Custom Cab…running project rockher_man Vehicles for Sale 8 07-26-2012 05:28 PM
