Center Console Door Rattle - Ford Truck Enthusiasts Forums
Old 09-12-2012, 08:14 PM
bridge's Avatar
bridge bridge is online now
bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.
Anyone else have a rattle of the latch on their center console door? For the last few weeks I've had the rattle I thought was the cup holders but, today I found the culprit. Its the latch hook, the part that locks into the center console. Its somewhat loose. Every time it rattles and my wife is in the car she gives me that look. You know, that look that says "You never should have bought this $60K truck that takes $4 gas. What were you thinking?" I hate that look.
Anyone know how to open the latch cover? I don't see any screws and I really don't want to experiement on a new truck. I have to take it to the dealer to fix the reverse camera but I haven't had much luck with Ford dealers addressing rattles.
Old 09-12-2012, 09:30 PM
maltesecross's Avatar
maltesecross maltesecross is offline
maltesecross is starting off with a positive reputation.
My center console was rattling quite a bit also. Come to find out the rubber bumpers the console sits on was missing. "Notice to the right of the latch in your pic what im talking about." You Might wanna check the other side. I didnt wanna bring it in for something that small. Ended up putting a piece of felt on the underside of the lid for now, no more rattle... U can count on me asking Ford for a new one at a later date tho. Good luck!
Old 09-12-2012, 09:39 PM
bridge's Avatar
Yup, all the bumpers are there. I removed one hoping to find a screw, no such luck. Need to find some way to tighten up that latch.
Old 09-12-2012, 09:47 PM
Adventure Rider's Avatar
Adventure Rider Adventure Rider is offline
Adventure Rider is gaining momentum as a positive member of FTE.
As a temporary fix you may want to add a wrap or 2 of electrical tape to the latching end
Wrap it opposite of how the latch goes down
Should take up some of the slop and deaden it while buying time to fix it permanent
Old 09-12-2012, 10:01 PM
olds403 olds403 is offline
olds403 is starting off with a positive reputation.
Mine does it too. I thought it was all the change in the rack i was keeping.
Old 09-12-2012, 10:06 PM
Schlava Schlava is offline
Schlava is gaining momentum as a positive member of FTE.
Mine did it since i bought it. Very simple fix. I used athletic tape and wrapped a small piece around itself a couple times to make a 1/4in lump. I stuck it in along where the front of the center consol door meets the front of the console. It hasn't made a sound since. In fact I did it a while ago and totally forgot it made any sound till I read this post!
Mark
2015 F150 Sport 4x4 passenger door rattles Jamessmith1 2015+ F150 0 03-29-2016 08:08 PM
What is the proper way to adjust F150 door latch/striker? 92 Red F150 1987 - 1996 F150 & Larger F-Series Trucks 20 02-10-2015 01:30 PM
bear claw latches and doors that rattle jhaas63 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 07-29-2014 09:37 AM
1990 f-250, passngr door won't close tight ham-n-swiss 1987 - 1996 F150 & Larger F-Series Trucks 6 06-27-2008 03:19 PM
Door Rattle brian42 General Diesel Discussion 12 05-13-2008 09:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
